FixYa.com
Aiwa AV-D58 5.1 Channels Receiver
All Products > Aiwa > Receivers
Problems with Aiwa AV-D58 5.1 Channels Receiver?
Troubleshooting and Support
Solved Problems for Aiwa AV-D58 5.1 Channels Receiver RSS Feed Post a New Problem
AIWA receiver
Hi Vinnie I've got the same problem with my AIWA receiver (I can turn the volume up is about 19 on the dial before...
1 Solution
how to get audio from sony flat screen to...
I am trying to figure out how to hook up audio from brand new sony Bravia flat screen to the Aiwa. The TV has both...
1 Solution
connection
may i ask how can i connect my PS3 to my receiver so can use surround sound
1 Solution
direct source
I pressed the direct source botton and now everytime I press another function I get the "can't use" message....
2 Solutions
AIWA AV S17
After a few moments it self siches to ECO and I would turn off my receiver, then back on and it still does the same...
1 Solution
Hooking Components
I need help hooking an Aiwa Receiver To a Sony VCR, And a Sharp TV and a GI Cable Box. Thank You
1 Solution
shuts down on it's own
After being on for 3 - 5 minutes, the system will shut down automatically. Will not power back up unless I unplug from...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Aiwa AV-D58 5.1 Channels Receiver RSS Feed Post a New Problem
won't come out of eco mode
Even after removing plug, stull comes on in eco mode with no other functions just red eco led on, how do i return to...
Post a Solution
no surround from speakers
receiver is in video 2 ,can't get surround speakers to work.
Post a Solution
Power and sound problems
My receiver get in silence suddenly...Sometimes I just switch CD or Turner and get back to Phono, then it get back play....
Post a Solution
AV-D58
All of a sudden the function knob feels loose and we can't select an option (ie CD, phono etc).  Is there any hope...
Post a Solution
Sound/Speaker? Issue
I recently was given an AV-D58 and I can only get sound to come out of the front speakers when I am in the "Source...
Post a Solution
Lost remote
Is there anyway to set speaker levels and turn on/off the subwoofer without a remote?
Post a Solution
cracking popping sounds
One day after a power surge, the system wouldn't turn on. I reset the surge protector, and it came on. But now I am...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeReceiver
Surround SoundDolby Digital® · DTS® · Dolby Pro Logic II
Number of Channels5.1 Channels
Stereo Mode Power80 Watt @ 8 ohm, 40 Hz - 20 kHz, THD: 1%
Surround Mode Power80 Watt @ 8 ohm, 40 Hz - 20 kHz, THD: 1%
THX CertificationNo
DSP
DSP ModesChurch · Disco · Hall · Movie · Live
Inputs / Outputs
Rear Input ConnectorsComposite (Video) x 2 · Digital Optical x 2 · Digital Coaxial x 2 · RCA (2 Audio Channels) x 6
Rear Output ConnectorsComposite (Video) x 2 · RCA (2 Audio Channels) x 2
Front A/V ConnectionsHeadphones x 1 · Composite x 1 · Couple RCA Jack x 1
Convenience
Tuner Presets32 Channels
Tone ControlsBass & Treble
Speaker Impedance8 ohm · 16 Ohm
Remote Control
DesignKeypad
Dimensions
Depth15.25 in.
Height6.13 in.
Width17 in.
Weight28 lb.
Warranty
Warranty1 Year
Aiwa Contact Information
Main support number1-800-289-AIWA
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
