Funai F42PDME 42 in. Plasma Television
Problems with Funai F42PDME 42 in. Plasma Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Funai F42PDME 42 in. Plasma Television RSS Feed
View More Results for Funai F42PDME 42 in. Plasma Television
Questions and Unsolved Support Problems
Unsolved Problems for Funai F42PDME 42 in. Plasma Television RSS Feed
Answer
Picture takes a few minutes to come up i've tried different connections and it's still real snowy... (More)
Answer
TV has a one foot section of yellow and pink mixture snow,cannot see images and starts at one end... (More)
Answer
I have a 42 Inch Funai Plasma. A couple of weeks ago a thick black line appeared down the middle. Do... (More)
Answer
my tv blue on button turns green far a second then turns off. can't get tv to come on vernon
Answer
same problem here...mine is also about 3 yrs old....anyone figure out a solution other than going... (More)
Answer
Hello, I have a Funai 42" Flat Panel TV model # F42PDME. Tonight when I turned it on the sound... (More)
Find a Manual
Funai F42PDME 42 in. Plasma Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
how to test flyback without taking it out of the board
a) basically it has to be acted upon by a supply voltage of at least 95V to work. b) of course, assuming the horizontal deflection oscillator works,... written by palaboy
LCD Flat Screen Common Problems
Have you ever wanted to know what causes a nice LCD to give out so soon? Poor electronics components such as Capacitors. I will tell you how to spot a... written by rulds2008
To preserve the life of all your electronics
If you have a tv, vcr, dvd player, anything at all that plugs into a wall, when you turn it off with the remote control, the unit is in standby, it... written by fieldy14
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for F42PDME 42 in. Plasma Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Funai F42PDME 42 in. Plasma Television
Write a review:
Rate this product:
Would you recommend the F42PDME 42 in. Plasma Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Funai F42PDME 42 in. Plasma Television
Key Features
Screen Size
42 inch
Flat Panel Type
Plasma
Display Resolution
852 x 480 pixels
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC
Display Format
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Remote Control
Remote Control
Standard
Image Quality
Contrast Ratio
1,000:1
Comb Filter
3DYC / 3D Digital
Brightness
470 cd/m²
Output Color
16.7 million colors
Viewing Angle
160
Audio Features
Secondary Audio Programming (SAP)
Without SAP
Technical Features
Picture in Picture
Without PIP
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Rear Input Connectors
Component x 2 · S-Video x 2 · Composite x 2 · Audio (RCA) x 4
Rear Output Connectors
Audio (RCA) x 1
Screen Text
OSD Languages
English · French · Spanish
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 5 Watt
Dimensions
Depth
5.88 in.
Height
27.5 in.
Width
51.75 in.
Weight
113 lb.
Warranty
Overall Warranty
1 Year
Funai Contact Information
Main support number800-242-7158
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
