20 Most Recent DeLonghi DR-18TG Oil Filled Radiator Heater Questions & Answers
3answers
Delonghi DR18T Timer Replacement
before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
3/25/2014 8:57:31 AM • DeLonghi DR-18TG... • Answered on Mar 25, 2014
0answers
How do I turn on my DeLonghi heater model 061567E
See this manual. It is of Delonghi HM25E type 061567T. It may help you. DELONGHI HM25E ELECTRIC HEATER IMPORTANT INSTRUCTIONS MANUAL ' ManualsLib
10/26/2023 3:08:31 PM • DeLonghi Heating... • Answered on Oct 26, 2023
Delonghi PAC A120EL Portable Air Conditioner. It is not cold?
Question edited for clarity. It probably needs a top up of refrigerant gas. Take it into a local refrigeration company.
6/28/2023 11:22:12 PM • DeLonghi Heating... • Answered on Jun 28, 2023
DeLonghi Oil Heater not shutting off.
That means that the switch is broken and is passing power when supposedly off. Claim on warranty, it is dangerous. If they say no, ask if there are any Class Action Lawsuits on it yet? https://www.delonghi.com/en-us/customer-service/warranty ..
3/16/2023 2:55:23 AM • DeLonghi Heating... • Answered on Mar 16, 2023
How to i get th case of a delonghi model pacan125hpec open?
:To open the case of a DeLonghi model PACAN125HPEC, locate the screws on the back of the unit and remove them. Once the screws are removed, carefully lift the back panel, being careful not to damage any of the internal components. The case should then open and you can access the internal components.
2/5/2023 5:12:15 AM • DeLonghi Heating... • Answered on Feb 05, 2023
2answers
How do you disassemble a delonghi portable air conditioner to replace the plastic fan squirrel cage?
See if there is a youtube video available or go to delonghi's web site to get a diagram
2/4/2023 7:31:13 PM • DeLonghi Heating... • Answered on Feb 04, 2023
Delonghi hifi heater keeps beeping control board green light
So, it sounds like your Delonghi hifi heater is giving you some trouble, man. The constant beeping and the green light on the control board, it's like it's trying to tell you something. My guess is that there's something funky going on with the thermostat. The beeping is probably the heater's way of saying it can't maintain the desired temperature because the thermostat isn't working properly. And the green light, it's like the heater is still getting power and trying to do its thing, but the thermostat is holding it back. One thing you could try is checking the thermostat settings and making sure they're all good to go. If the settings are chill, but the problem persists, it might be time for a new thermostat. You could also try unplugging the heater for a bit and then plugging it back in, see if that helps reset the system. If all else fails, it's best to reach out to Delonghi's customer service or maybe even a professional technician to take a look and give it a tune-up. It's not always easy to fix these things ourselves, so don't be afraid to ask for help.
1/15/2023 5:15:40 PM • DeLonghi Heating... • Answered on Jan 15, 2023
DeLonghi PACN130HPE Pinguino N Series 13000 BTU 115-Volt Air-to-Air Portable Air Conditioner with Heat Pump. It beeps then shuts off and buzzes while plugged in with no displays on-screen
Question edited for clarity, full 'make model (what it is)'. Question moved to correct category. You have done everything you can do. Take it to a DeLonghi service centre or to a refrigeration engineer. The buzzing is likely the compressor and needs a new start / run capacitor. https://www.google.com/search?q=delonghi+pacn130hpe+portable+AC+buzzing+noise ..
11/18/2022 7:24:57 PM • DeLonghi Heating... • Answered on Nov 18, 2022
Where can I get a manual for my DeLonghi HM-25 oil filled heater?
google DeLonghi HM-25 manual
12/29/2021 12:40:49 AM • DeLonghi Heating... • Answered on Dec 29, 2021
What is the meaning of CL with a warning sign
HELLO, THIS IS A SYSTEM WARNING ON AN AIR CONDITION ,THAT MEANS LOW CONDITION OR CONDITION LOW. THANKS
7/2/2021 7:49:25 AM • DeLonghi Heating... • Answered on Jul 02, 2021
Model dedw645S. What is E1 error?
have a Delonghi dishwasher DEDW645S which shows E1 error code on the front ... If so, can i have the full model number of the machine. For more click here
4/23/2021 4:52:22 AM • DeLonghi Heating... • Answered on Apr 23, 2021
I have a Delonghi MG15EW oil filled heater thats emits a smell of hot plastic, but only at the high setting. Any idea what is causing this?
The high heat setting is affecting the plastic control panel, causing it to emit fumes.
12/24/2020 10:32:07 PM • DeLonghi Heating... • Answered on Dec 24, 2020
Cpc505 AU. How many kw is it?
12/16/2020 11:16:27 PM • DeLonghi Heating... • Answered on Dec 16, 2020
I have a Delonghi heater type 2507. Does it have built thermostat inside?h
This vehicle is not on board programmable and requires a qualified professional to program smart key remote fobs. 1. Locate an automotive locksmith in your area using the phone number or website below. 2. If your vehicle is still mobile, it may save you money by driving to the locksmith instead of having them come to you. 3. The locksmith will then hook up specialized computer equipment to your vehicle in order to program the smart key remote fob. Hopefully that gives you you answer you looking for.
12/7/2019 3:49:49 PM • DeLonghi Heating... • Answered on Dec 07, 2019
2answers
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
9/12/2019 6:50:54 AM • DeLonghi Heating... • Answered on Sep 12, 2019
Delonghi PAC AN125HPEK=X: what size drainage hose does it take (for draining the water)
Have a look at the bottom where the drain outlet is and measure the size of the outlet. Its probably a 3/4 inch or 1 inch
8/19/2019 2:02:36 AM • DeLonghi Heating... • Answered on Aug 19, 2019
DeLonghi DR-18TG Oil Filled Radiator Heater Logo
5 questions posted
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • DeLonghi Heating & Cooling
Most Popular Question
delonghi dr18t timer replacement
  • Heating & Cooling
