20 Most Recent
VIA ASRock K7VM3 Socket A/ KM266PRO/FSB333/DDR333/A&V&L/Modem/MATX MotherBoard (MOTASR09) Questions & Answers
I need drivers for VGA graphics Adapter...DELL
Hello you can download the driver here:http://www.dell.com/support/drivers/us/en/19/Product/vostro-3300There are too different ones soo you have to try it.The files must be unzip before installation.Good luck
Sound is not coming
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Shut down after 5 - 10 min.
the most likely case is CPU-OVERHEAT EMERGENCY POWEROFF command executed by motherboard
in this case apply new thermoaste on cpu, and clean fan/replace on bigger if doesn't help/cpu is overclocked
I want VGA drivers for VIA chipset 8233
hiiii
Please goto this site i.e. http://www.viaarena.com/default.aspx?PageID=2
and as per your selection of OS you can find you driver of your motherboard.
I need mainboard drivers
go to www.driverguide.com make a free account and download your required drivers for free...
best regards,
K7vm3 mobo RAM
If you are referring to the ASROCK mobo then it will work on the high density although not as good as with the low density but it will nontheless work.
K7VM3
An ASRock
K7VM3.motherboard is a socket A (462) board specifically for the AMD processors. To my experience, these boards (
due to age and period of usage) are prone to:
- bulging/leaky capacitors of the high current regulators near the CPU;
- the heatsink tends to be dislodged/misaligned causing overheated processor;
- loose memory slots causing defective memories.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Bad graphic
Your motherboard only supports AGP. You can use any AGP graphics card that supports up to 4X AGP. nVidia and ATI make great cards as well as other manufacturers that mak boards using nVidia and ATI chipsets. I would recomend a card with at least 512MB of memory onboard. I hope this helps.
Lou
Video driver
Vista Black edition is a pirate copy of Vista, it is probably infected by some malware that will slow the entire system down in time, not just the video display
