20 Most Recent Canon Eos 1ds 1d 5d Mark Mk I Ii Iii Iv Questions & Answers
You use Live view to get an accurate focus then turn live view off and then once 2 sec delay has been selected (this can be done before going into Live View) release the shutter.
Canon Eos 1ds 1d... | Answered on Jan 29, 2017
If it will sort out a problem which you may have, good idea.
Canon Cameras | Answered on Jun 08, 2019
Fixya does not sell battery case doors for a canon powershot a 560.
Canon Cameras | Answered on May 28, 2019
Your manual can be downloaded from the Canon website here
http://gdlp01.c-wss.com/gds/0/0300004720/02/eosrt3i-eos600d-im2-c-en.pdf
Video tutorials as well
https://www.google.com/search?rls=com.microsoft%3Aen-US%3AIE-ContextMenu&ei=YPXqXKiJK8WO5wKktrigAg&q=canon+rebel+t3i+manual&oq=Canon+rebel+t3i+m&gs_l=psy-ab.1.0.0l10.4079.4401..5878...0.0..0.99.181.2......0....1..gws-wiz.......0i71j0i67.7FoNdMzDqQQ
Canon Cameras | Answered on May 26, 2019
Good Day
Remove and re-insert the batteries. Might be related to the non-standard accessories or batteries or the non-standard remote connected. Also you can try remove your lens and make sure that the connection is clean, be careful not to touch any of the surface inside the camera as this may lead to damage, if there is no dust or dirt where the lens connects to the camera I suggest you take it to you local dealer for assessment.
Hope you find a solution here
Canon Cameras | Answered on May 21, 2019
The "Consecutive" shutter release setting is the default for Sports Mode so if you are using that you'll have to just practice a lighter touch on the button. Otherwise, and this is from memory, press "Menu" find "Drive" or a little icon that looks like a small stack of pictures and switch the setting to "S" for Single.
Canon Cameras | Answered on May 17, 2019
Have you check the memory card? Can you see the image file in the memory card? If not, I think you deleted them accidently, and if you want to get all the photo back, you have to ask recovery for help, know more here:Recover photo from memory card
Canon Cameras | Answered on May 15, 2019
This may mean that either the catch or spring has broken. Expensive to get repaired - either raise the flash manually, or use an external flash unit in the hotshoe.
Canon Cameras | Answered on May 05, 2019
You basically decide on the kind of photo you want to take, then follow the instructions in the manual to achieve those results, changing them if necessary to improve the image.
Canon Cameras | Answered on May 04, 2019
You don't.
Dots per inch (dpi) is an output parameter when printing your pictures. It's often determined by the printer and its driver.
The camera has no idea what printer(s) you are using. Since it has to put something in the dpi field, it selects 72. Most cameras do the same.
The dpi will change depending on the size of the print.
You can change the dpi field using any good photo editing program.
Canon Cameras | Answered on May 02, 2019
Canon Eos 1ds 1d 5d Mark Mk I Ii Iii Iv Logo
2 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
live view doesnt allow operation 2 sec
  • Cameras
