Home
My Products
Sign In
All Products
Haden
Toasters
Problems with Haden 10941 4-Slice Toaster?
Add to Warranty Manager
Search inside
Knowledgebase
Troubleshooting and Support
Post a New Problem
Why does my Toaster Oven heat differently...
Why does my Toaster Oven heat differently than my Conventional Oven?
1 Solution
Failure of toaster oven
After using the toaster at lunch time, the coils failed to light for dinner. Thetimer was still working, but,...
1 Solution
Lever on taoster will not stay down
the right side facing lever will not stay down. when i hold the lever down, there is no heat generating from the...
2 Solutions
Russell Hobbs Toaster Model # RH4T9379
The toaster failes to raise the bread after toasted. One side only does not perform.
1 Solution
Bread won't toast
Lever won't stay down when depressed (ie pushed down, not sad)
1 Solution
eliment
top eliment wont work on toaster oven
1 Solution
Di Longhi Toaster oven
Heating element is splitting.Where can I replace the elements? Thank you, E. Grob ecgrob@aol.com
1 Solution
View All
Tips & Tricks
Post a New Tip
Be the first to Post a New Tip
WikiManual
Post a New Chapter
Be the first to Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Be the First to upload Manual or Guide
Specifications
Key Features
Number of Slices
4 Slice Toaster
Extra Wide Slots
With Extra Wide Slots
Other Features
Crumb Tray
With Crumb Tray
Cancel Button
With Cancel Button
Sponsored Links
Bogda
Let one of our
Experts Solve
your Problem
DO YOU WORK FOR
HADEN
Register as STAFF
New Products
Powered by
Repair Service
Find Toaster Repairman Near You:
Advertise Here
powered
by
Get this Widget
