20 Most Recent
Funai F3813D 13 in. Combo Questions & Answers
Attach new antenna wire to tuner (Funai TV VCR combo )
If you take off the tuner cover you should see where another wire was attached to the PCB as there will be a small hole with nothing connected and a piece of wire at board level or broken level with the Printed curcuit board. If you dont see it then the best thing for you to do is to send the tuner to a tuner repair place like PTS tuner service and they have a flat rate to overhaul tuners and assy's or see how inexpensive a new tuner assy is. Its available at pts electronics for 49.95 along with many many more items like rebuilt printed curcuit boards ect ect ..www.ptscorp.com Good mluck
Funai dvd recorder e3 error
THat means it is unable to record successfully.
Try cleaning the lens with compressed air in a tin, (used for cleaning).
Do Not use a cleaning disc, as that can lead to permanent damage to the lens and focus coils.
How to reset my funai TV resolution mismatch
On your remote control, press MENU.
Highlight Settings with the down arrow button, then push OK.
Press OK after highlighting Television with the down arrow button.
Select TV resolution, then click OK.
Select HD 720p, HD 1080i, or HD 1080p using the arrow buttons.
Click OK.
FUNAI
What's the question?
