20 Most Recent
Haier FSW116W Stand (Pedestal) Fan Questions & Answers
Speed switch wiring
You can get a three speed switch almost anywhere, but if you want the correct one then I need to know how many wires are on the capacitor & what color wire goes into which slot of the switch.
Haier gas dryer rdg350aw won't heat up
Let's troubleshoot this issue and find a compatible heating element.
Check the Igniter: The igniter is responsible for lighting the gas burner. If it's faulty, the dryer won't heat. Inspect the igniter for any visible cracks or damage. If needed, replace it.
Thermal Fuse: The thermal fuse is a safety device that cuts off power to the heating element if the dryer overheats. Check if the thermal fuse is blown (no continuity). If so, replace it.
Gas Valve Solenoids: These solenoids control the gas flow to the burner. If they're defective, the dryer won't heat. Test them for continuity using a multimeter. Replace if necessary.
Heating Element: Since you specifically asked about the heating element, let's focus on that. The compatible heating element for your Haier gas dryer model RDG350AW is the Haier Dryer Heating Element (Genuine OEM Part # WE11X27362). You can find it online or at appliance parts stores.
3/7/2024 7:07:58 AM •
Haier Dryers
Answered
on Mar 07, 2024
Where is the thermal fuse on Haier Dryer model HLTD600AEW?
The location of the thermal fuse on a Haier Dryer model HLTD600AEW may vary depending on the specific model and design of the dryer. However, in general, the thermal fuse is usually located near the heating element or the exhaust duct. It may be hidden behind a panel or tucked away in a hard-to-reach area. In some cases, it may be necessary to consult the user manual or contact the manufacturer for specific instructions on how to locate the thermal fuse on a Haier Dryer model HLTD600AEW.
1/20/2023 5:53:31 PM •
Haier Dryers
Answered
on Jan 20, 2023
Haier dryer rde 350 aw will not start beep and a click is all i get
Based on the description provided, it sounds like there could be an issue with the start button or the control board on your Haier RDE 350 AW dryer.
- Check that the start button is not stuck or malfunctioning. If the button is stuck, it may not be able to send the proper signal to the control board to start the dryer.
- If the start button is working properly, the issue may be with the control board. The control board is responsible for sending power to the various components of the dryer, including the motor. If the control board is malfunctioning, it may not be able to send the necessary power to the motor, resulting in the clicking noise you're hearing.
If the above solutions don't resolve the issue, it's best to contact Haier customer service for further assistance. They can provide troubleshooting steps or arrange for a technician to come out and look at the dryer. Request for a senior technician or supervisor to take a look at it and provide a resolution.
1/18/2023 12:00:46 AM •
Haier Dryers
Answered
on Jan 18, 2023
Where is the thermal fuse located on a Haier RDE350AW dryer ?
Not exactly a fuse for drying heat, the electric motor would have a thermal fuse strapped into the winding.
The dryer exhaust hot air chimney, just after the drum, would have both a thermostat and a high heat limit called thermodisk cut off and clixon by trade name.
Find the wiring diagram inside the dryer panels to reveal color wires going to what you need finding.
8/19/2019 1:16:39 AM •
Haier Dryers
Answered
on Aug 19, 2019
How do you turn off the beaping on a Haier Clothes Dryer?
The responses here miss the issue: The beeps described by the Poster are NORMAL and signal a finished load. However, the beeps are very loud, persistent, and extremely annoying, therefore the Poster wants to DISABLE the beeps. The question is how to disable the annoying beeps.
12/11/2018 12:23:35 AM •
Haier Dryers
Answered
on Dec 11, 2018
