20 Most Recent Toshiba 32LV67U 32 in. HDTV LCD TV/DVD Combo Questions & Answers
Check the power supply.
Toshiba 32LV67U... | Answered on Oct 28, 2017
usually in main menu there is an input and you select the cable option .
Toshiba 32LV67U... | Answered on Jul 26, 2015
Sometimes there is a volume on older cable boxes. Unfortuanately adjusting the volume can be a chore because most cable remotes are volume locked to the TV input. You can try and press the cable button on your cable box remote and see if the volume will adjust, if not I would call your cable company and see if they can help, and possibly replace the box. Usually you can take the box to a store for your provider in the area and they can swap it out.
Toshiba 32LV67U... | Answered on Apr 10, 2014
Might be the power supply, try out a company named ShopJimmy.com. They have been great to me in the past and are always helpful. I included a link from your model page on their site. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=32LV67U
Toshiba 32LV67U... | Answered on Aug 30, 2011
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
So you do not have cable service, taht means you are using Out-door, or In-door antenna to get the off the air signals? Your TV has ATSC tuner to receive digital Off the Air signal uisng antenna, so you do do not need to use the converter box.
To get a lot of Channel, you must have good antenna and the TV stations must not be blocked by tall buildings or mountains, which may explain why you are not getting many stations.
You may have to install good out door antenna to get more stations.
The spec of your TV:
http://www.consumersearch.com/tv-dvd-combos/toshiba-regza-32lv67u/specs
Tuner ATSC/NTSC/QAM
Toshiba 32LV67U... | Answered on Jan 27, 2011
Hi Robert,
I have included 2 links that may be able to help you resolve your issue.
Good luck,
JP
https://www.manualslib.com/products/Toshiba-Rc1910-4064538.html
https://www.youtube.com/watch?v=j8OQq7W_rew
Toshiba... | Answered Yesterday
How old is the TV? Does it have a marketplace of apps that came preloaded? Is there a search button in that screen? If so search for the app, you can also search for Amazon prime Video App that comes with Hulu.
It is out there, that if you have internet enabled on the Toshiba BD player, did you need to stop or disable the internet capability.
Toshiba... | Answered on Jul 06, 2019
Toshiba 32LV67U 32 in. HDTV LCD TV/DVD Combo Logo
11 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
toshiba 32lv67u first started
  • Televison & Video
