dvp sr200p installation; I have a direct tv box; old standard tv. I can get the blue screen...
(More)
dvp sr200p installation; I have a direct tv box; old standard tv. I can get the blue screen (sometimes) but it goes black
I have a DVD Player APEX AD-1165 and it stopped working after about 4 months. It won't read any DVD,...
(More)
I have a DVD Player APEX AD-1165 and it stopped working after about 4 months. It won't read any DVD, whether it is new or copied. What can cause that?
I inherited my late mothers POS Apex dvd player & I was going to throw it on my driveway to make...
(More)
I inherited my late mothers POS Apex dvd player & I was going to throw it on my driveway to make myself feel better after it kept trying to load and would just open & shut. I opened it up (if for nothing else to learn something) & the slide tray is functioning correctly but the spindle thing isn't "popping up" to grab & spin it. I tapped it a couple of times & it popped up. it would also pop up and catch if I rotated the disc with my finger.... it also loads & plays afterwards The old man told me to just lube it up but trying to search for a solution makes me think not so I figured I would ask the pro's. Thankyou much!
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
