Apex Digital GB55HD09W 55 in. Rear Projection Television
Problems with Apex Digital GB55HD09W 55 in. Rear Projection...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Apex Digital GB55HD09W 55 in. Rear...
Troubleshooting and Support
Solved Problems for Apex Digital GB55HD09W 55 in. Rear Projection Television RSS Feed
View More Results for Apex Digital GB55HD09W 55 in. Rear Projection Television
Questions and Unsolved Support Problems
Unsolved Problems for Apex Digital GB55HD09W 55 in. Rear Projection Television RSS Feed
Answer
My Apex GB55HD09w rear projection turns on for about 2 3 minutes then shuts off"
Answer
we have a toshiba april 2002, model number: 50h81,serial number:56232093, chassis no: TAC 0151... (More)
Answer
It seems that the colors are OK, and the audio is OK also. The picture is about three to four inches... (More)
Answer
I know there is some way to separate the two parts to the tv for easier moving but I cannot figure... (More)
Answer
when tv is turned on picture is fine for a while than goes into a double picture.
Answer
ok picture is ok very clear my problem is if something is on that a ticker is going i can not see it... (More)
Find a Manual
Apex Digital GB55HD09W 55 in. Rear Projection Television Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Apex Digital GB55HD09W 55 in. Rear Projection...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Why my TV does not start up and remains in standby?
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also ensure that the fault is not coming from a faulty receiver... written by ginko
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Mitsubishi Green Blinking light of death
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made... written by SD Tech
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W.. · Symptom: No Convergence, Picture is bowed and distorted,... written by johnnydiode
Samsung Color Wheel replacement!
This varies a little depending on model number of the set. Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some... written by SD Tech
Sony KP51hw40 etc with Blue screen and or Shuts down
Many of these sets had problems with bad picture Tubes--they use a red, green and blue crt. Most commonly the blue gives troubles--The tubes are now... written by SD Tech
PANASONIC CONVERGENCE DO IT YOURSELF REPAIR
So many people ask me about this here are my Instructions if convergence will not adjust and or is skewed: PANASONIC CONVERGENCE... written by SD Tech
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Apex Digital GB55HD09W 55 in. Rear Projection Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Apex Digital GB55HD09W 55 in. Rear Projection Television
Key Features
Screen Size
55 inch
Display Capabilities
Aspect Ratio
16:9
Remote Control
Remote Control
Universal
Image Quality
Velocity Scan Modulation
With VSM
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Variable
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Dimensions
Depth
24 in.
Height
53 in.
Width
51 in.
Warranty
Overall Warranty
1 Year
Tube Warranty
2 Years
Apex Digital Contact Information
Main support number866-427-3946
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
