20 Most Recent Apex Digital GB43HD09 43" Rear Projection HDTV-Ready Television Questions & Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apex Digital... | Answered on Mar 13, 2017
In a APEX set change the convergence chips (2) AND use the original remote to adjust the set. There are several sites like TV parts.com that sell kits based on brand and model number.
Apex Digital... | Answered on May 01, 2012
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apex Digital... | Answered on Aug 14, 2010
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Hi
Thanks for using FixYa. It is convergence (STK) ICs (Chips) which needs to be replaced and not the convergence board. It’s not a difficult job if you want to do this yourself. To start with you’ll need to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts. Please see the pictures to recognize STK ICs (Chips) shown with arrows---
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Apex Digital... | Answered on Jul 31, 2010
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apex Digital... | Answered on May 15, 2010
hello, the convergence ic's have gone bad in your tv . and sometimes they fail because of a 50 mfd @ 50v capacitor by each ic goes bad. if you have the skill at soldiering and desoldiering you may try repairing it yourself otherwise leave it to a qualified repairman. thanks .....techman...580-243-8025
Apex Digital... | Answered on Apr 01, 2010
http://rds.yahoo.com/_ylt=A0geu.ZgCKhLgjIAXBFXNyoA;_ylu=X3oDMTEzbGQ5ZTZnBHNlYwNzcgRwb3MDMwRjb2xvA2FjMgR2dGlkA0g1MzJfMTQ2/SIG=126kbj3eb/EXP=1269389792/**http%3a//www.apexdigitalinc.com/manual/GB43HD09W.pdf
Here is your manual if all it is is adjustment. It most likely is the IC's that go bad that handle the convergence circuits. It is not hard usually, but you do need some electronic skills to get this done right. Brad
Apex Digital... | Answered on Mar 23, 2010
Sounds Like your convergence ICs big black ICs will part number on them example STK394-020 Call Mats for Parts on ICs 1-800-628-1118 Also Call Encompass you can order whole Board if you want to you just unplug old board and plug in new 1-800-638-3328
Apex Digital... | Answered on Oct 01, 2009
thecnical problem may be it a fuse on the main board or power supply.
Apex Digital... | Answered on Sep 04, 2009
Click HERE to see HDMI Jack image, if it is there at back of TV then OK and if do not, then TV has No HDMI facility.
Apex Digital... | Answered on Apr 28, 2009
This TV probably uses two convergence IC Packs that will need to be replaced and be re-converged. There may also be a resistor or two that may need replacing as well. The projection tubes should last another 3 years or so.
Apex Digital... | Answered on Feb 20, 2009
If you are using a cable box, go into the general settings on cable box, use cable remote. Go to "viewer power on", and you can chose what channel you want the tv to turn on to .
Apex Digital... | Answered on Jan 28, 2009
yes those ICs will work in your model. You can get replacement ICs and free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Apex Digital... | Answered on Nov 30, 2008
Hi
it is necessary to replace 2 convergence Ic's associated resistors test and repair power supply voltages , then performed a convergence alignment all of this could be around $ 120.00 in parts. go to www.vancebaldwin.com for parts
You rating to my answer is highly appreciate
Apex Digital... | Answered on Sep 06, 2008
The circuit board on the right hand side is either cracked or the soldering came loose, I took mine apart and found it by mistake, everytime I pulled up the board i had picture again, so I propped up the board with some dumb-dumb and it has still been working, there are no parts for this TV
Apex Digital... | Answered on Feb 02, 2008
If this is the clear smooth screen, yes you can go to your local glass & paint store & have a new protective screen cut for that size. If this is the screen with thin lines etched in it from top to bottom..vertically is the Lenticular lens & no there is no way to repair, you must replace, with new or used. Go to ebay under projection tv parts see if you can locate someone having your size for sale & bid on it or email them to outright purchase it.
Apex Digital... | Answered on Jul 22, 2007
If you have homeowners insurance and can file a claim on it, perhaps your insurance adjuster knows of a shop that could handle this problem. Most likely you will be needing the power board replaced, p/n 8667200700T unless it can be repaired. The schematic for this set is not listed as an available part for this set (In the future it would be very wise to stay away from any manufacturer that does not support what they make). After restoring power to the set, you could find that there are other problems such as a defective tuner or audio/video problems due to the power surge. It may be possible to fix the power supply without a schematic if that is the only part that has been damaged.
Apex Digital... | Answered on Dec 20, 2006
Apex Digital GB43HD09 43" Rear Projection HDTV-Ready Television Logo
Popular Tags
29 questions posted
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Apex Digital Televison & Video
Most Popular Question
43 apex ha tv
  • Televison & Video
