20 Most Recent Panasonic EUR511511 Remote Control Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
The problem you posted here is difficult to understand. Provide more details, please.
Panasonic... | Answered on Aug 16, 2014
download the instruction manual +code > www.fitness.manualsonline.com
or www.remotecodelist.com or www.retrevoc.com
God bless you
Panasonic... | Answered on May 15, 2012
I'm not sure I understand;however, you may log onto www.Panasonic.com, then go to remotes, then troubleshooting. Most likely it will ONLY take a few easy steps to follow before your remote is up and running again. Good luck!
Panasonic... | Answered on Jan 28, 2011
IPTV subscription is a something that I wish had came out years ago. There are several ways to get IPTV, but the most simple way to get it is on your existing android box if you have one. You can also buy an IPTV box like the Mag 254 that is primarily used for IPTV. Couple of the best providers that I like are RocketStreams and IPGUYS. They both have great service.
If you need more info about IPTV and what its all about, check out the link below. Its a blog post that talks about some good providers and what you can expect from them. Hope this helps. Cheers
IPTV Subscription For Your Android Box Should buy Subscription
Panasonic... | Answered Yesterday
Keep pressing OK + 2 or OK + 3 depending on the case for about 5 seconds.
The remote should work then.
Hope this helps!
Panasonic... | Answered 2 days ago
Probably an open internal fuse or power supply failure
Panasonic... | Answered on Jan 14, 2019
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}
Panasonic... | Answered on Jan 13, 2019
http://www.tv-forums.com/forum/TV_Equipment_C4/LCD_TV_Forum_F41/Panasonic_lcd_Tc-32lx60l_with_blinking_stby_light._P151410/
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the APh
board, A board, or the LCD panel.
Panasonic... | Answered on Jan 12, 2019
I hate to give you the bad news but that's a 2005 model and it wasn't exactly a high-end one. It would be cheaper to simply to go get a new one. Sorry
Panasonic... | Answered on Jan 11, 2019
To output audio, use the stereo cable to connect the camcorder to the TV (insert terminals other than the yellow one). 3. Turn on the camcorder and the TV. On the TV, select the component terminal to which you connected the camcorder as thevideo input.22 Jul 2010
Panasonic... | Answered on Jan 10, 2019
Use code search on your Magnavox URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Subtitles come from your cable or satellite box, so look on the remote for that device rather than the television settings. Google
make model of box, remove subtitles
Panasonic... | Answered on Jan 08, 2019
Panasonic EUR511511 Remote Control Logo
Popular Tags
3 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
gorenje error codes
  • Televison & Video
