20 Most Recent Polaroid External Top Load DVD/CD Writer RW208 (Black) Burner Questions & Answers
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
http://www.driver-fix.com/scan.php?id=scan5&key=2
Drivers Freeware
Now you can download driver updates automatically and safely. This handy software utility will keep your system up to date by automatically getting the latest drivers from your hardware
Polaroid... | Answered on Nov 02, 2011
There should be no need to install any software to make it work. It should be automatically recognized when you plug it in.
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this dvd/cd writer then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Polaroid... | Answered on Jan 14, 2011
Try resetting the tv to default settings.if that doesn't work try resetting your router.
Polaroid... | Answered on Apr 28, 2019
You could do a factory reset. Read before you try it; you'll lose any data accumulated.
http://www.mobicpc.com/how-to-hard-reset-polaroid-10-1-to-factory-default-setting.html
This might give you a soft reset though it's written for the S7:
Resetting Polaroid S7 is a bit tricky.
  1. Turn off the tablet.
  2. Press and hold the volume up and the power buttons together for 5 seconds then release them.
  3. You have to wait for the Android picture to show up on the screen now.
  4. Only after this screen is shown, press and hold the power and volume up buttons together for 3 seconds.
  5. Release the volume up button
  6. Now, release the power button. You will enter the recovery menu.
  7. Now, use the volume buttons to navigate and the power button to select items.
  8. Navigate to and select "wipe data/factory reset".
  9. Navigate to and select "yes -- delete all user data".
  10. Navigate to and select "reboot system now".
  11. The phone will be rebooting
    . Do not press anything while that is happening until the start-up screen shows up (the one with "Make yourself at home").
Polaroid... | Answered on May 27, 2018
This is a media player. It has a Linux OS. That is not Android, Apple, or Microsoft. It can accept downloads of the media files it was designed to play via a special USB cable connected to your computer. It is not designed to accept a browser, but rather media files such as music and ebooks. Those may be exported from the computer to the Polaroid media player. Programs stay on your computer, media files may be exported to your device or its SD card. There is a customer support number at the end of the document below.
http://www.southerntelecom.com/polariodsupport/downloads/PMP700.pdf
Polaroid... | Answered on Jun 11, 2017
Polaroid External Top Load DVD/CD Writer RW208 (Black) Burner Logo
Popular Tags
3 questions posted
Top Polaroid Computers & Internet Experts
micky dee
Tom Chichester
Steve P
Steve P
Are you a Polaroid Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Computers & Internet
Most Popular Question
recently burner stopped working want
  • Computers & Internet
