20 Most Recent
Canon EOS 500D EOS Rebel T1i Digital Camera with 18135mm lens Questions & Answers
Why suddenly all the pictures
You've probably got your camera in the black-and-white mode. Look through the viewfinder. Does it say "B/W" just to the right of the ISO?
If so, press cursor-down to bring up the Picture Style menu. Use the cursor keys to select the desired style and press SET. Full details are in the "Selecting a Picture Style" section of the manual (page 73 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://www.usa.canon.com/cusa/consumer/products/cameras/slr_cameras/eos_rebel_t1i_ef_s_18_55mm_is_kit#BrochuresAndManuals
If you're not in the black-and-white mode, please feel free to reply to this post. Please specify the picture style(s) you're using. Are you seeing B/W on both the review and when you download your pictures?
Tried to take pictures of lightening last night
For this kind of pictures, Don't try to focus on a lightning, it is to quick and mabe the overall brightness is not enough for your camera to focus.
So you can try to focus on something at infinity, if you manage then, put your focus on manual before re focusing, this way you will be able to take as many pictures as you want.
You can also try to focus manually directly.
And for you information the best way to take a lightning picture is to put your camera in bulb mode, use a remote control, open the shutter and close it as soon as you'v seen a lightning.
Hope this helps.
and good shooting !
7d - problem with shots remaining
Maximum for counter is 999. Counter is showing 999 because you have space available for more than 999 shots. If you've got a very large memory card it may tke quite some time to get below 999.
1/13/2018 7:54:04 PM •
Canon Eos...
Answered
on Jan 13, 2018
Top edge of my photo is a black diagonal shadow
Sounds like it could be vignetting from either a lens hood or an accessory. Are you seeing this in all photos or flash only? If flash, sometimes a wide shot with a lens hood on will block the flash output and cause the described shadow line.
11/17/2017 10:46:15 PM •
Canon Eos...
Answered
on Nov 17, 2017
Why is there nothing showing in my lcd after I turn camera on?
This is an indication that the LCD is not functioning. You haven't indicated the make and model of your camera but if it has a view finder, try taking some picture and view them in a computer. No view-finder? Just point and shoot some subjects and view then from a computer.
Are the pictures OK? If they are than you might want to maintain that style while looking for replacement parts of service tech.
10/28/2015 1:31:45 AM •
Canon Eos...
Answered
on Oct 28, 2015
I am unable to take photos using my EFS 18-55 lens
When you have another lens, that still works on the same camera, you can assume it is something with the 18-55. Please check carefully if all contacts are clean and shiny. Also check if not one has a (even tiny) bent to dent.
You can clean contacts with a dry cloth, or cotton swab. Never use anything sharp in or lost by a camera.
If you can't fine anything obvious wrong with the contacts, I think you should visit a Canon certified service centre.
Came just in my mind. If the camera does not give any error, and you still can shoot (blurred) pictures, check if the AF switch is not on manual.
11/20/2014 7:06:55 PM •
Canon Eos...
Answered
on Nov 20, 2014
How do I install the ds 126071 0n my laptop?
Although the manual does not show how to connect to a computer, the system map shows how to use a mini USB cable to connect the camera to a PC. But before the camera will communicate with any PC or Laptop, it needs software.
From the Canon USA website you still can download the Zoombrowser EX software for free. It used to be the EOS Digital solution disk and the ArcSoft PhotoStudio Disk.
Before connecting the camera, install the software. Then when software (and driver) are installed, when connecting the camera, the software will start up and ask what to do. Like import the pictures to the computer.
Success
11/20/2014 4:26:51 PM •
Canon Eos...
Answered
on Nov 20, 2014
Won't down load photos
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
10/9/2014 4:29:01 AM •
Canon Eos...
Answered
on Oct 09, 2014
When I switch on it automatically keeps taking images and won't stop.
Sounds as though moisture is closing the shutter release contact or has damaged it. You can try wrapping the camera in a clean, paper bag without the lens and battery and open the battery and memory card door as well as the other covers. Then place the bag in a large bowl or box of clean, dry, uncooked white rice, completely covering it, for at least a week to draw moisture out of the camera. You can also use a commercially available moisture desiccant but they're more expensive and the rice works pretty well. If that doesn't help send the camera in for repair as soon as possible. The longer you wait, the more damage can be done by trapped moisture.
8/14/2014 12:23:27 PM •
Canon Eos...
Answered
on Aug 14, 2014
