20 Most Recent
Onkyo TXNR808 Receiver Questions & Answers
TX-NR808 audio unexpectedly off
Hello, I am sorry about your issue. Please contact Onkyo at 800-229-1687 option #3 so that we can discuss options. Thank you, Onkyo USA.
My Onkyo 808 shuts down when i raise the volume,
Amps shut down in most cases because the receiver is detecting and impedance (below 4 ohms) that might damage the amplifier. Do a quick check of the speaker connection and look for wires that might be shorted to the frame or have crossed each other. This is the most common cause of the unit shutting down. Check your speakers impedance if you have a meter. If you don't then unplug power from the unit and then un-hook all speaker wires from the receiver. Next connect just one speaker (Front Left) and power the unit back on and take the volume up. If it shuts down then try the Front right all by itself, bring the volume up again. If the unit seems ok then add one speaker at a time and test. Continue until you find the bad speaker/cable. Your amp should be able to drive speakers down to 4 ohms. The NR808 has power monitoring (sometimes called crowbar) that looks for to much current and then shuts down. I suspect you may have a short in a cable or in a speaker. The 808 is a great amp and hopefully your problem is external. If your amp continues to shut down even with just one speaker connected then one or more of your channel amps (internal) is likley bad causing the unit to shut down. Good Luck.
Hi,at first my 808 had
This problem could be caused by a lot of things. The remote control not working could be as a result of the batteries so get replacement batteries.If the batteries are not the problem then the remote is old and due for replacement.
The receiver on the other hand is having the problems it is having due to either old age or there is a malfunction in the unit control board which controls the functions. Simply get the unit serviced at the local dealer so it functions properly again.
Hope this solution has been helpful?
My speakers klipsch rf82 II are rated at 8ohms and
Nope.. 8 ohm's is the best speaker for it, anyway. receiver will run coler
just leave the settings as default. it just means that any speaker above 4ohm is ok to use it.
but if you use a 2ohm you will burn the amp..* ohm is perfect. for this amp.
When i hooked up onkyo
Have you defined the presence of the center speaker, like you will also have to do for the sub when you get one?
Have Onkyo TX-NR808 receiver. Not
The problem is the audio output ic's, one or more channels has developed a short causing the safety shutdown to engage. The only solution is take it back where it was purchased and since it is under warranty it should be repaired free of charge if not a possible exchange.
0-83 error on onkyo tx nr 555
The 0-83 error indicates a problem with the firmware update.
Try resetting the receiver's BIOS by following these steps2:
Unplug all cables
Un-Power the receiver
Power the receiver
Before the receiver gets into the "Enter for updating" message, press Tone + CBL/SAT + ON/STANDBY. This will show you either the volume numbers or get you into settings of the receiver's speaker configuration.
Press CBL/SAT + ON/STANDBY. This will clear the BIOS and show a "Clear" message on the display. Wait until you hear a couple of clicking sounds for the receiver to turn on and off the power.
TX-NR555 Owner's Manual - Onkyo Product Support (onkyousa.com)
Onkyo nr 555 stuck on recovery:NET
Hello
Did you update the AVR over the internet?
If so the device wont work anymore.
You need to service the device in a nearest Onkyo service department.
Regards
Onkyo powered subwoofer SKW-791
Oknkyo SKW-791 has build in amplifier. So it can be connected through Line Out Connector of sansui amplifier. If speakers out is connected with subwoofer, the circuit board in subwoofer will be blown.
What's the error M1.04/19912A50?
The error code M1.04/19912A50 on your Onkyo AV receiver HT-R398 typically indicates a firmware or software-related issue. To resolve this problem and reset your receiver, you can follow these steps:
- Power Cycle the Receiver:
- Turn off the receiver and unplug it from the power source.
- Wait for about 10-15 minutes to ensure that all internal components have fully powered down.
- Plug the receiver back in and turn it on.
- Factory Reset:
- If the error persists after power cycling, you may need to perform a factory reset to restore the receiver to its default settings. Note that this will erase all your custom settings, so make sure to back up any important configurations if possible.
- To perform a factory reset, refer to your receiver's user manual for specific instructions. Typically, this involves pressing and holding specific buttons on the front panel while powering on the receiver. The exact combination of buttons may vary by model.
- Firmware Update:
- Ensure that your receiver's firmware is up to date. Visit the Onkyo website and check if there are any firmware updates available for your HT-R398 model. If updates are available, follow the provided instructions to update the firmware.
- Contact Customer Support:
- If the issue persists after trying the above steps, it's a good idea to contact Onkyo customer support or visit their official support website. They may be able to provide specific guidance or solutions for the error code you're encountering.
Remember to consult your receiver's user manual for model-specific instructions, as the steps to reset or update firmware can vary between different Onkyo models. Additionally, be cautious when performing a factory reset, as it will erase all settings and return the receiver to its default state.
