Sanyo PLC-SW30 Multimedia Projector
Problems with Sanyo PLC-SW30 Multimedia Projector?
Troubleshooting and Support
Solved Problems for Sanyo PLC-SW30 Multimedia Projector RSS Feed Post a New Problem
Sanyo pro x multiverse projector
Hi i've got a projector as listed above and although it is an old model i have only just got round to setting it up due...
3 Solutions
big blue dot
my projector is showing a large blue dot on the screen, and im stumped to why this is happening. i've cleaned the lens...
2 Solutions
sanyo projector plc sw30
I have a sanyo projector plc sw30 and am trying to connect it with my philips dvd home theatre system. it is showing the...
1 Solution
i turn the remote receiver off
i was browsing the menu in the projector and acidentally i turned the remote control off.now i cant turn it on.
1 Solution
Sanyo PLC-SW30
Projector is ceiling mounted projecting onto an interactive whiteboard. Recently the projected image developed a yellow...
1 Solution
screen size problem!!
i have turned the dial on the front but its at the smallest it will go!! is it something to do with trying to run it...
1 Solution
screen size
i have just brought my projector back from my home in spain and set it up here in the uk, but i have left manual back in...
1 Solution
Unsolved Support Problems
Unsolved Problems for Sanyo PLC-SW30 Multimedia Projector RSS Feed Post a New Problem
sudden power cut happened while thw...
Hi, I was watching a movie on the projector, when a sudden power cut happened it didn't get enough time too cooll off,...
Post a Solution
Sanyo PLC-SW30 Multimedia... Problem
Projector is powering on. Where do I find the fuse.?
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformPC · Mac
TypeLCD Projector
Form FactorPortable
Display TechnologyTFT Active Matrix
Image Brightness1250 ANSI lumens
Contrast Ratio300:1
Max Resolution (Native)800 x 600
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)34 in. - 200 in.
Screen Distance4.27 ft. - 21.33 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Horizontal15 - 80 kHz
Synchronization Range Vertical50 - 100 Hz
Technical Features
Audio OutputSpeaker(s)
Operation Noise37 dB
Interfaces
InterfaceSerial (RS232) · USB · Infrared
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · Composite Video · Component Video
Lamp
Lamp TypeUHP
Light Source Life2500 Hours
Light Source Power160W UHP
Other Features
Special FeaturesKeystone Correction
Speakers Output.8 W
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43
HDTV Formats720p · 1080i · 480p · 480i · 1035i · 575i · 575p
Warranty
Warranty2 Years
Dimensions
Depth7.48 in.
Height3.07 in.
Width10.63 in.
Weight4.19 lb.
Sanyo Contact Information
Main support number(800) 421-5013
Email supportsupport@sanyotv.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
Marrie Wiz
15 solutions
Ask Me
dhiman Wiz
9 solutions
Ask Me
gaz1958 Master
4 solutions
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
