20 Most Recent Vizio m420nv 42 in. LCD HDTV Questions & Answers
Chances are its not caps that are causing this issue, that isn't a symptom of failing filters. If your comfortable around higher DC voltages I can give you some information on what to test if your not take it in for repair however expect the bill to start at 100 dollars and go up from there
Vizio m420nv 42... | Answered on Mar 05, 2018
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Vizio m420nv 42... | Answered on Dec 01, 2015
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Vizio m420nv 42... | Answered on Jul 15, 2015
Check whether the audio is muted by accidently. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Vizio m420nv 42... | Answered on Nov 07, 2014
Vizio m420nv 42 in. LCD HDTV Logo
72 questions posted
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
wel vizio tv lost sound
  • Televison & Video
