20 Most Recent Cyberhome CH-LDV1010A Portable DVD Player Questions & Answers
your set needs a tech take it to be repair you cannot do it yourself if you do not have a knowledge of electronics repair.good luck
Cyberhome... | Answered on Feb 15, 2017
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Cyberhome... | Answered on Jul 03, 2015
Faulty or dirty laser, fault on decoder board or the motor the disc sits on is stuck of faulty
Cyberhome... | Answered on Sep 28, 2014
try Ebay & overstock.com
I would say under $20
Cyberhome... | Answered on Jun 09, 2011
there are sadly no after market batts for these dvd playes and the company in tw does not sell them direct
sorry
hope this helped
Cyberhome... | Answered on May 03, 2011
First you need to try other disc on it to confirm if it is not the disc you were trying to play, if it does the same, then the lens of the player is faulty.
Therefore the reason your portable dvd player keeps reading disc without playing it is either because the lens of the player is weak or dirty.
Try to clean it with a dvd lens cleaner and test it with a disc after cleaning it. if it does the same, then the problem is that the lens is weak and needs replacement.
To replace the lens, get the appropriate screwdriver, unscrew the player from the bottom, you will see the battery and panel of the player, carefully unscrew it and remove the panel, you will see the compartment where the lens of the player is seated, carefully detach it from the player and replace it with a new one. Then you reverse the process to reassemble the player back together.
Take care
Cyberhome... | Answered on Jun 29, 2010
I have two of these batteriers if you still need them. I'd rather not throw them away if they could be put to use. You pay shipping they are yours for free.
Frank
Cyberhome... | Answered on Aug 20, 2009
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Cyberhome... | Answered on Feb 04, 2009
Sorry nto tell ya that something must have happened to the lcd screen or display. Has it been dropped ?? If you hold it up to a light do you see an image but no brightness as could also be a backlight problem . My advice would be to see if theres any type of warrantee on the unit cause from experience this repair PROBably is'ent gonna be cheap and I say this cause most repair centers wont even look at something like this for under 30 to 50 bucks. Good Luck
Cyberhome... | Answered on Dec 08, 2008
Romy... there are "membrane switches" located behind the front panel. Sometimes they go bad or get dirty and won't work.
MOST times these are a SINGLE panel with many switches. Often they are a pain to GET and install... Only the right one will work!
switch-o5myk4hhi5b5q5if45zblvzs-4-2.png Anthony
Cyberhome... | Answered on May 20, 2018
Cyberhome CH-LDV1010A Portable DVD Player Logo
16 questions posted
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Cyberhome Televison & Video
Most Popular Question
need battery ch ldv 1010rs portable dvd
  • Televison & Video
