20 Most Recent Brother Dcp395cn InkJet Printer Questions & Answers
Black Ink is blocked and
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
8/7/2011 8:49:24 AM • Brother Dcp395cn... • Answered on Aug 07, 2011
It's a brand new printer and it will not print
You can try calling Brother at 1-877-276-8437 and they should be able to tell you where to take the unit to have it repaired under the warranty. This is a very common problem that Brother is well aware of; the printhead will need to be replaced.
6/9/2011 1:52:25 PM • Brother Dcp395cn... • Answered on Jun 09, 2011
My brother printer DCP 395CN
Some printers automatically print automatic duplex printing, other printers allow you to manually reinsert pages to print the second side .and some printers do not support duplex printing at all.
To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box
Note that If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
3/28/2011 12:53:33 PM • Brother Dcp395cn... • Answered on Mar 28, 2011
Brand new printer photos look bland
Make sure the cartridges are proper and there is no dust on nozzle just clean with tissue paper and also use brother photo quality paper that is special type paper use that.
Hope this helps. Please rate my response.Thanks.Have a good day
12/29/2010 4:30:11 AM • Brother Dcp395cn... • Answered on Dec 29, 2010
Printer idle for some months and now wont print
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.Post / thumbs / testimonial are welcome!
12/12/2010 2:36:48 AM • Brother Dcp395cn... • Answered on Dec 12, 2010
2answers
How do i download instructions for brother printer
Should be able to find everything you need here:
http://welcome.solutions.brother.com/BSC/public/as/au/en/model_top/colormfc/dcp395cn_all.html?reg=as&c=au&lang=en&prod=dcp395cn_all
Trust this is helpful. Please vote. :)
12/11/2010 9:57:55 AM • Brother Dcp395cn... • Answered on Dec 11, 2010
Anyone can help me with my DCP-T720DW printer, machine error 7E00.How can I fix this?
Remove the jammed paper. • Check that the paper is set in the paper tray correctly. • Check that there is not too much paper set in the paper tray. • Check that the thickness of the paper is within the standard. • Check that the size of the paper is within the standard. • Flip through the paper and reset it in the paper tray.
10/21/2021 6:42:14 AM • Brother DCP... • Answered on Oct 21, 2021
Unable to init.50 MFC-J220
Recommend contacting Brother directly easy-oqy5fah40apqzze5k2tsaxfy-2-0_1.png
8/1/2021 7:36:27 AM • Brother DCP... • Answered on Aug 01, 2021
Brother control center 4 won't open on my computer
This may help others with scanning issues: I just bought a Brother MFCJ6510 printer/scanner and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked. The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs. Hope this helps somebody else as frustrated as I was.
7/31/2021 11:48:16 AM • Brother DCP... • Answered on Jul 31, 2021
Toner ended error in brother dcp 1511
Refill or replace toner.
7/31/2021 11:05:39 AM • Brother DCP... • Answered on Jul 31, 2021
Genuine brother ink cartridge not detected by printer on DCP J315W printer
This is a common occurrence for these machines. They can get confused when cartridges are changed before they read as empty. To correct this. 1) Unplug the printer from both the Power and Computer and remove all cartridges closing the cartridge access panel. 2) Plug the printer into the Power only and turn on. The machine will complain about no cartridges, this is fine. 3) Open Ink access panel and insert the first cartridge (Black is most common and close the panel. 4) The machine will complain about the missing cartridges. Open the panel and insert the second cartridge in the sequence and close the panel again. 5) Repeat the process for the third and fourth cartridge. 6) Once all cartridges have been installed the printer will ask if you have replaced the cartridges. Say no to the Black, Cyan and Yellow but yes to the Magenta and it will display the correct readings. If this process fails to read the cartridge still then there is something wrong with the sensor inside the machine which probably means new machine.
7/30/2021 12:34:19 PM • Brother DCP... • Answered on Jul 30, 2021
DCP-J315W shows "Unable to Init 4F"
Turn off the printer and unplug it from the power. Then press and hold the power button for 1 minute. Now release the button, plug in the printer and turn it on and see if the error clears. If it doesn't fix the issue, you probably have to replace the cartridges. They will cost about $65. Good luck!
7/30/2021 11:38:27 AM • Brother DCP... • Answered on Jul 30, 2021
Hello.At first my machine (brother DCP-165C) showed "Clean Unable 50" error.After that I reset purge counter.Then the machine showed "init unable 46".I tried to update the main firmware by brother fir
Remove and clean the pads in the waste ink chamber inside the machine. Then perform the purge reset.
9/30/2018 9:26:53 PM • Brother DCP... • Answered on Sep 30, 2018
2answers
How to clear init Un able 50 message to function the printer
maintenance unit is not working normally. See if any thing is stuck or replace it.
9/2/2017 8:31:30 AM • Brother DCP... • Answered on Sep 02, 2017
How solution Unebal to EF in Brother DCP 7055 matchine ?
Error code EF - Irregular power supply is detected Print Unable EF Turn the power off and then back on again.
5/25/2017 1:35:34 AM • Brother DCP... • Answered on May 25, 2017
How do I fix my brother printer USB not recognised
See if you can find the printer driver online (manufacturer's web-page maybe) and install the driver before you connect the printer.
8/19/2016 8:04:34 PM • Brother DCP... • Answered on Aug 19, 2016
Brother Dcp395cn InkJet Printer Logo
Popular Tags
11 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
DCP Brother
  • DCP Brother
Most Popular Question
black ink blocked
  • Office Equipment & Supplies
