FixYa.com
Sharp SharpVision XV-ZW99U Multimedia Projector
All Products > Sharp > Multimedia Projectors
Problems with Sharp SharpVision XV-ZW99U Multimedia Projector?
Search inside Sharp SharpVision XV-ZW99U Multimedia... Knowledgebase
Troubleshooting and Support
Solved Problems for Sharp SharpVision XV-ZW99U Multimedia Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
How do I adjust the frequency for an...
How do I adjust the frequency for an external monitor (projector)?
1 Solution
my problem is that the Image is not...
my problem is that the Image is not stable, on my projector, any suggestions?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Epson EMP-82e locked out
One of our staff turned off the projectors power. He then proceeded to input the wrong security code and the projector...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
green tint
I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Sharp SharpVision XV-ZW99U Multimedia Projector RSS Feed Post a New Problem
during play, entire unit went off and will...
xv-zw99u projector. No picture, no lights, nothing. Checked all power sources to the projector to include home fuse box...
Post a Solution
Sharp xv zw99u
Projector will play, then sound stays on screen goes dead. After unit is turned off for a few hours, picture will then...
Post a Solution
Sharp Vision XVZW99U LCD projector
I recently bought a second hand projector and am wondering how to get it to work with my Dell laptop. The seller hooked...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeLCD Projector
Form FactorStationary
Display TechnologyTFT Active Matrix
Image Brightness400 ANSI lumens
Max Resolution (Native)832 x 624
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Image Size (Diagonal)25 in. - 300 in.
Color Support24-bit (16.7M colors)
Technical Features
Audio OutputSpeaker(s)
Lamp
Lamp TypeMetal Halide
Standards
Analog Video FormatNTSC
Warranty
Warranty1 Year
Dimensions
Depth20.72 in.
Height7.72 in.
Width14.03 in.
Weight31.97 lb.
Sharp Contact Information
Main support number1-800-237-4277, 1-800-BE SHARP
Support FAX1-630-378-9981
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
