20 Most Recent Epiphone Amplifiers SoCal 50H Amp Head Questions & Answers
Have recently added to or changed your speaker config? Are all tubes seated and glowing nicely? Any smell? Worse case, you popped a tranny.
Epiphone... | Answered on Dec 12, 2017
It is likely either a diode or capacitor has failed in the power supply OR much less likely is one of the final power tubes has a short.
Continuing to replace fuses MAY cause further damage to components. Take unit in for repair.
Epiphone... | Answered on Dec 21, 2010
Request the wiring diagram directly from Epiphone.
Epiphone Music | Answered on Oct 02, 2018
That serial number was used more than once.
If it has 'Made in USA' on the headstock, it was made at the Bozeman Plant, MT, USA on July 21st, 2000.
Otherwise it was made in Korea in March, 2002.
Epiphone Music | Answered on Mar 31, 2018
That guitar was made in Korea in August, 2004
Epiphone Music | Answered on Jan 25, 2018
We don't do that here, check with them...
Epiphone Music | Answered on Dec 15, 2017
Your guitar was made at the Qingdao Plant (Epiphone), China in April, 2016
Epiphone Music | Answered on Nov 27, 2017
Does this guitar have a esonic 2 system, if so the other pickup is piezo pickup located under the saddle, there should be two wires coming from the pre-amp just remove the pre-amp from the body and make sure that the two wires are still plugged in and attached to the pickups, these are plugs like a small headphone style plug, just check these and the wires are held in by small wire clips,one of the wires may have came out of the clips...hope this helps I will look for a schematic for you and post it if I find one...Good Luck!!!
Epiphone Music | Answered on Nov 18, 2017
I think it was made at the Muse factory in China in Jan 2011
Epiphone Music | Answered on Oct 05, 2017
Not the model, as Epiphone did not assign serial numbers that way.
Your guitar was made at the Saein Plant, Korea, in March, 2000. They made a lot of Epi Les Paul models tho.
Epiphone Music | Answered on Aug 12, 2017
Finally caught up to this.
Your guitar was made at the Fuji-gen Plant, Japan in 2006
Epiphone Music | Answered on Aug 02, 2017
Epiphone Amplifiers SoCal 50H Amp Head Logo
Popular Tags
6 questions posted
Top Epiphone Music Experts
Robert Graf
Craig Butler
Craig Butler
Miguel Luiz Martins
Are you an Epiphone Music Expert? Answer questions, earn points and help others
View Most Popular
Epiphone Music
  • Epiphone Music
Most Popular Question
strike note sustain drops out as
  • Music
