20 Most Recent Sharp XR-1S Multimedia Projector Questions & Answers
OK - I've fixed mine (so it looks) - loads of dust inside unit seemed to caused the problem - vacuuming vents (as the manual prescribes) just shifts all the dust inside around and obviously causes some disruption.. solution - remove 4 screws underneath and lift off top (carefully) remove side panel screws (where Av inputs are) again carefully. Now go around each vent at the front, side and underneath and give areal good blow in each a few times. Plumes of dust and rubbish fly out - keep going until it's all clear. Reassemble and fingers crossed. Mine then started up and didn't turn off - there's a horrible burning smell (dust settling near lamp I presume) which is now fading. Been working 30 mins now with no trouble!
Hope it works for you - will post another update if I have any further problems - no news is good news!
Grahamkida
Sharp XR-1S... | Answered on Jun 27, 2012
projector is running but the lamp is not on and after a while the temp light comes on
Sharp XR-1S... | Answered on Feb 15, 2011
hi,
first of all check the tint setting on your projectors picture menu.
if not get the correct color then, your projector is a dlp projector that means it have a color wheel in side. if the synchronization of color wheel is not correct this problem can occur. there is a sensor for couting the rpm of color wheel. also have a black mark on the color wheels rotating portion. the sensor scene this black mark for making count. if there is any dust in that portion it will make difficult to the sensor making the counts. you have to remove the color wheel to clean the same.
i have added a video how to clean the color wheel . not the same projector.
ok
Sharp XR-1S... | Answered on Feb 02, 2011
could be a blown fuse
Sharp XR-1S... | Answered on Jan 22, 2011
for gray scale rs.5,000/- For original rs.20,000/-
Sharp XR-1S... | Answered on Jan 16, 2011
It is 1100 lumen or ANSI projector.Less the projection distance you get better result
Sharp XR-1S... | Answered on Mar 03, 2010
P/n for the power supply: RDENCA075WJZZ
Sharp XR-1S... | Answered on Feb 26, 2010
the power supply is bad and need to be replaced. you can get the part and do it yourself, or send it to a sharp service center. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Sharp XR-1S... | Answered on Jan 27, 2010
you'd be better off hooking the dvd up to an amp and run speakers off of that.
Sharp XR-1S... | Answered on Aug 19, 2009
press menu, scr-adj, prj mode, then select front.
Sharp XR-1S... | Answered on Aug 06, 2009
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Sharp XR-1S... | Answered on Jul 23, 2009
I have a Notevision Sharp xr-1s projector and it wont work with my windows vista laptop. I tried it on my vista pc and xp laptop and it works fine.
Sharp XR-1S... | Answered on Sep 06, 2008
Sharp XR-1S Multimedia Projector Logo
28 questions posted
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
sharp xr 1s projector need replace
  • Office Equipment & Supplies
