20 Most Recent
Mad Catz Call of Duty Black Ops PrecisionAIM Controller Questions & Answers
How to buy a power charger for my trio
walmart has them or amazon mat be cheaper
google search>>> try entering the search like this>>> charger for(your trio model number) amazon. if you dont have a credit card to make the purchase online do the search anyway because you should be able to get the model number for the charger you need,then you can go to a retail store like walmaert. walmart carries universal adapter chargers also. if they dont have what you need in store go to the help center and they will have it shipped to that store. Its much easier to do this online @ walmart.com then all you have to do is go to the store and pick the item up when it arives in a few days
I have a madcatz call of duty black ops controll, it charges when i connect it but wont connect to my ps3? help me!
You need to sync your controller with the ps3, put the USB dongle into one of the available slots on the ps3 - exactly where you would normally connect a wired controller on the front. Now switch on your ps3, the dongle will connect, now put your USB cable into the black ops controller and switch on - your 4 lights should be flashing on the controller. Now press connect on the USB dongle, your controller should now sync to the ps3 and hopefully will show as controller No 1. Remove the USB cable and play wireless.
My mad catz controller will not configure to my
sir good day there are two way on how to configure your wireless controller to your ps3 console.... the automatic pairing and a manual pairingfirst way an automatic pairing1.turn on your ps3..2.Connect the smaller end of the included USB cable to the PS3 controller.3.Connect the opposite end into either USB port on the front of the PS3.
The pair light on the PS3 will flash. When it stabilizes, you can
disconnect the USB cable and use the controller wirelessly.second way a manual pairing1.. turn your ps3..2.Connect the smaller end of the included USB cable to the PS3 controller.3.Connect the opposite end into either USB port on the front of the PS3.
Press the "PS" button on the center of the PS3 controller. The pair
light on the controller will flash. When it stabilizes, you can
disconnect the USB cable and use the controller wirelessly.you can try that 2 way on how to configure your controller to your ps3 console if this help you please rate me thank you sir..
Hi I can't seem to
Try another controller that you know the vibration is working properly. If it works then you know the original controller is faulty. Those wireless controllers have a little motor that vibrates and they can go bad after alot of use, or if they get thrown around, etc.
I would like to know
Your problem isn't with the USB slot, it's the battery itself. Abuse to the battery (letting it die often, overcharging it for extended periods of time, etc.) can degrade the amount of power the battery can hold, along with the fact that lithium ion batteries eventually do lose their charge capacity after a certain amount of time. Your best bet is probably to just buy a new controller.
When using my PS3 COD
It sound like the controller is faulty. I suggest returning it. with PS3 controllers 3 party brands tend to be cheaply built. Its best to buy sony's controllers.
My wireless mad catz controller wont connect. the
Mad Catz has been known to cause hardware problems with Sony units. However, it sounds like you are just having a sync problem. Try plugging in a USB Cable to the PS3, connecting it to the controller, then pressing the Home button.
