20 Most Recent Waring WCT708 4-Slice Toaster Questions & Answers
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Waring WCT708... | Answered on Apr 10, 2014
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Waring WCT708... | Answered on Mar 04, 2013
The holder is a bimetallic strip that heats up and opens when it reaches a preset temperature based on the darkness setting. It should latch onto the toast loading mechanism when cold and then snap open when it reaches a certain temperature. The darkness setting knob adjusts the point at which it opens. Probably either the release mechanism is broken or bent or the setting knob is broken. You can disassemble it when unplugged by removing the screws on the bottom and prying off the toast loading knobs by placing a ruler wrapped in cloth against the housing and prying the knobs off with a large screwdriver carefully going back and forth from side to side. If the knobs break or won't go back on use a high temperature epoxy to reassemble. You have a good side to compare the bad side to. Look for differences from one side to the other as the toast loader lever goes down and as the darkness knob is rotated. You may just have something blocking the mechanism. After working on it, plug it in outside to a ground-fault protected outlet on a fireproof surface before attempting to use it.
Waring WCT708... | Answered on Nov 30, 2007
If it is a removable cord, you will get one in a good electrical shop, or online by describing the connector.
If hard wired, you can buy a plug with wire attached at home depot and fix it yourself by removing the place where the wire goes in.
https://www.google.com/search?q=new+cord+for+my+old+Waring+Steam+Chef+CS510
This shows the model. It has a special bespoke connector
https://www.worthpoint.com/worthopedia/waring-steam-chef-cs510-model-11cs12-253544648
You can get a new, used on one for 20 bucks.
https://www.ebay.com/c/1301639892
Waring Kitchen... | Answered on Jul 09, 2019
The reset can trip if there is a short circuit or the unit is over-heating. Either condition is dangerous. Unless you can locate the problem, for safety reasons suggest replace the entire unit with a new one.
Waring Kitchen... | Answered on Apr 23, 2019
Linkco perhaps. That may be a general supplier.
Waring Kitchen... | Answered on Jan 19, 2019
Kudos to the person(s) that identified the safety switch on the housing. Mine would not turn on because the switch would not depress, perhaps the plastic insertion piece on the frame was a little off. I tried wedging aluminum foil and plastic etc, but if you don't depress the black button in the middle of that white shroud on the switch exactly right, it won't work.
My solution was to permanently attach a 1/2 inch deck screw thru the housing so that the screw tip keeps the switch depressed always.
Turn the unit on its left side, use a very small bit to make a pilot for your screw. Very carefully and slowly screw down until the tip activates the switch. I don't believe there is a circuit board or anything in the vicinity, and I left mine plugged in so I would know when I hit paydirt. Caveat emptor and good luck!
Waring Kitchen... | Answered on Dec 22, 2018
Waring WCT708 4-Slice Toaster Logo
14 questions posted
Top Waring Kitchen Appliances - Others Experts
Jim
Bruce Eichhorst
Ps Daengr
Ps Daengr
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Waring Kitchen Appliances - Others
Most Popular Question
toaster lever wont stay down
  • Kitchen Appliances - Others
