FixYa.com
WeatherWorks DB888 Floor / Box Fan
All Products > WeatherWorks > Electric Fans
Problems with WeatherWorks DB888 Floor / Box Fan?
Search inside WeatherWorks DB888 Floor / Box Fan Knowledgebase
Troubleshooting and Support
Solved Problems for WeatherWorks DB888 Floor / Box Fan RSS Feed Post a New Problem
Need fan blade.
I need a new fan blade for a Weather Works model DB888 box fan. I can't find any links to parts on the Weather Works...
1 Solution
Wires for fan speed came undone.
The part underneath the fan speed control came apart and the wires are just hanging. The part has numbers 1, 2, 3 and...
1 Solution
blown subwoofers
can they be fixed or is it better if i buy new ones. 2 have a little sound but the other 4 have no sound at all.
1 Solution
I have a 36 inch ceiling fan with four...
I have a 36 inch ceiling fan with four wooden blades. The thing always ran with a little wobble, but after it was taken...
1 Solution
fan problem
whines when turned on. seems to be either a grinding or a off-balance of blade and shaft
1 Solution
I removed the old fan & light. There...
I removed the old fan & light. There are 3 wires coming out of the ceiling - white, black & red. The wires...
1 Solution
blade problem
I have a nice hunter ceiling fan, a 56" I think. Four blades with three screw holes each. The rubber bushings for...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for WeatherWorks DB888 Floor / Box Fan RSS Feed Post a New Problem
200 WeatherWorks DB888 Floor / Box Fan...
We are didtrubutors in Home Appliance However; we bought a shippment of WeatherWorks Fans and many of the blades need...
Post a Solution
DB888
Need Blade to purchase living in guyana
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeFloor / Box
Speeds3 Speeds
Blades
Number Of Blades3 Blades
Blades Diameter20 in.
WeatherWorks Contact Information
Main support number1 - 800 ? 427 - 3456
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
