20 Most Recent
Master Heaters HarvestMaster Climate Pro Plus Controller Questions & Answers
The heater in my subaru legacy does not get hot.
A few things to check:
- Is your coolant level low? If so add coolant to the proper level.
- Does it get warm at all or is it always very cold. If it gets just a little warm but not good and hot it could be your thermostat is stuck open. A quick way to check this is, after driving for long enough to warm the engine up good, what does the temperature gage in the car read? If it is steadily below the midway point (where it should normally reside at operating temperature), then your thermostat is stuck open and is not allowing the coolant to warm up enough to produce hot air.
These are the most likely candidates. It could be an electrical problem with the HVAC temperature control but that's not likely.
My doorbell has gone quiet
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
How can I reset my floureon h 264?
Press the reset button: Using a small tool like a toothpick or paperclip, press and hold the reset button for a few seconds until the DVR resets. This will restore the DVR to its factory settings, including the default password
