20 Most Recent
XFX GeForce Fx 5900xt Graphic Card Questions & Answers
My w\vista when i first tern it on and the compact
Ouch. I hope you didn't break anything. I would take the battery out of your laptop and then put it back in and make sure the battery isn't dead. USUALLY when a laptop powers off it is a power issue. However, since you said you dropped it, there may be other motherboard damage and it may need to be serviced.
Vist Home standard
Roger, This sounds like more of a hardware issue, Check the BIOS for any changes. I would set to system defaults.
Try to boot to safe mode see if there are any driver issues.
You didn't mention how old it is. I assume the it is still under warranty. In that case I would let the factory take care of it.
How do I reinstall my graphics card since I installed win 7 pro
Hi
I presume that the installation of Win7Pro was an upgrade from a previous OS and that the graphics card was obtained before Win7 was available, as this would explain the lack of drivers for Win7Pro on the disk. If you go here:
AMD Catalyst Display Driver
you will be taken straight to a page where you can download the drivers for installation.
Hope this is helpful, if so would you please register that with Fixya
Cheers
No sound xfx one
You must set up port in drivers and in windows
analog for speakers and headset, or
digital for hdmi to tv speakers
How to repair msi vr320x with no display?
Does both the port not giving you display did you check the memories is it all fine set also the power you have connected it properly try it in different machine check the PCIE Volts which slot is suitable for your Card on your motherboard.
try the display cables and cooling all ok than i am afraid you need to send it to a workshop or you can fix if you know chip level work so there is An IC if fails or leak it does not give any out put so you need to change that.
Nvidia 9600 gt
Maybe you have set the view to large icons in properties.
