20 Most Recent
Spectralink NetLink e340 Wireless Telephone (Mitel and ROHS Requires BPE100) Questions & Answers
Cordless phone won't recharge
is it the charger or the batteries. you should be able to pick up a charger / power supply at most electrical outlets or eBay with correct voltage and amps out put. If you have a problem with the plug end of the charger you can cut and join to new one.
Jeff
How to unmute or restore
User options
Press FCN while on hook to change settings
(* shows current, follow display instructions to set):
Ring Type-select:
Normal (for an audible ring)
Vib/Norm (vibrates for five seconds, then rings)
Vibrate (vibrates until answered)
High Noise Mode-select:
Normal (for most office environments)
High (for moderate background noise)
Severe (for extremely noisy conditions)
Current IP address: may not be edited.
Extension number: may not be present for some protocols.
Additional options may be present
How to identify a genx scanner device for Windows 7
When you have no driver for this Windows version and the former did not work, even in compatibility mode, then try the free program IrfanView. In the File menu first go to Select scanner source. VueScan is also a program supporting many scanners but not free.
How to change tax rate on spl-290 calculator
* Press *N/C/CE *****n* Enter 200* Press the TAX+ *****n* The display will sh*w the t*tal price TAX+ 210* Press the TAX+ *****n again* The display will sh*w the tax am*unt TAX 10* *r the price after tax is $58.5, what is the pre-tax price and tax am*unt:* Press *N/C/CE *****n* Enter 58.5* Press the TAX- *****n* The display will sh*w the pre-tax price TAX- 55.72* Press the TAX- *****n again* The display will sh*w the tax am*unt TAX 2.78
My conlog is showing minus - 11.06 kwh
You mentioned a reading of minus 11.06 kWh. Here's what it means:
Remember that this is a prepaid meter, so the negative value suggests that you've used more energy than what was prepaid
The meter has consumed 11.06 kilowatt-hours (kWh) more energy than it has generated or received.
This negative value indicates that more energy was used than supplied during the specified period.
LED Indicator:
The meter has an LED light that flashes when electricity is consumed.
When you use electricity, the meter balance decreases, and the LED light provides a visual indication of energy flow.
Plz tell me error code 21 how to fix it for ultrasonic comfort 400 nebulizsr
As you know, this is a medical device. I suggest you consult a medical professional about it as it affects your treatment. The device is Japanese in origin. The instruction manuals I encounter are written in Japanese. That may or may not prove to be an impediment to you contacting the company yourself for guidance. I am reluctant to advise you about the equipment as my guidance would be very, very general and your health is much too important for trial and error. A low battery can generate error messages. Turning it off, unplugging it, waiting a few minutes, plugging it back in and turning it on might clear the problem. Some nebulizers have a reset button.; I can't say being unable to read the manual readily. Assuring all its parts are assembled correctly is of course worth doing. The company: Koushin Industries, Inc. (Japan):
Address: 1000-1, Hirakata, Ageo, Saitama, 362-0059, Japan.
Phone: You can reach them at the provided address.
Website: Visit their website for more information: Koushin Industries, Inc. However, I find the information there to be in Japanese. Again, I suggest you consult a medical professional.
MERA WORKCENTRE 5016 U2 ERROR CODE PROBLEM
Refer to pages 92 and 98 in the manual regarding error code. Switching it off and on may help (page 32). If such does not resolve the issue, you may have to consult your system administrator or the Xerox Welcome Center. 1 (800) 835-6100
