20 Most Recent
Goodmans GPDR40 Digital Media Player Questions & Answers
Have no power threw mains or computer will not
Hi pmp86,
No power could be a result of a failed SMPS , so you can use your friend's SMPS for some time , and then when you connect it accordingly to find that things work fine , then you need to replace the SMPS box from your cabinet which has the power cables along with it.
Hope this helps..:)
Need installation disk for goodmans gpdr40
go to the mustek site & download the software for the h140 , it is the same software as I have both units , the only problem is neither vista or windows 7 will run the software
Data loading... pls help me
OK you need to restore data follow this steps:
use getdata back for Fat file system or get data back for ntfs
If you need help let me know
Regards
Ok use getdata back for Fat file system or get data back for ntfs
Regards
[email protected]
Cant load videos of any format
There are 2 ways to get movies onto this unit, 1 is to use trhe supplied cable plugged directly from a video or dvd player and set the unit to record if it is set up correctly then the picture of what is being recorded should be on the screen. also be sure to have the unit plugged into the mains while recording. the second way to get a recording is not to use the supplied coverter software as it is rubbish and takes forever.instead get a copy of ArcSoft MediaConvertor which will convert most formats to the .ASF Format required for this unit, it works very well and only takes a couple of minutes.........
