20 Most Recent JCPenney Gyropter RC Helicopter Questions & Answers
Need an instruction manual for a Gyropter R/C, 3-channel helicopter
HelloCouldn't exactly find the manual but,here's video tutorials you might want to have a look at:http://www.youtube.com/watch?v=i2zWi4lMxxkHope it helps.Ken
1/14/2024 2:03:02 AM • JCPenney... • Answered on Jan 14, 2024
0answers
I need the instructions Manual for a gyropter. Can you send it to me?
Look online for a manual. Searching "Propel Gyropter Manual" Should bring up at least a pdf manual. Chaio!
11/29/2015 10:11:30 PM • JCPenney... • Answered on Nov 29, 2015
Gyropter makes sound but propellers do not move.
there might be hair or fur stuck in your parts check that out
7/20/2015 7:32:36 PM • JCPenney... • Answered on Jul 20, 2015
My helicopter is not turning on after it fell down and the charger is full.
Hi make sure you are on correct channel. Usually there are A B C channels. Look on your heli and try each one :)
7/20/2015 5:49:36 AM • JCPenney... • Answered on Jul 20, 2015
Top propeller won't spin
The drive gear is either not engaged no or has stripped teeth.
2/1/2015 6:35:47 PM • JCPenney... • Answered on Feb 01, 2015
Gyropter RC helicopter replacement parts
Replacement parts can be found on amazon, take a look: Amazon com Gyropter RC parts. I hope this was helpful. cheers
12/10/2014 8:22:44 PM • JCPenney... • Answered on Dec 10, 2014
MY GYROPTER WILL NOT FLY.
I charged my gyropter ,and the bottom propeller spins slowly and makes a noise.
3/18/2014 1:00:07 AM • JCPenney... • Answered on Mar 18, 2014
2answers
Chopper spins clockwise . How do I fix it
It is spinning around because one of the rotors is not spinning at full speed. This happens when you bump a spinning rotor against something. Determine which one it is by observation or logic (i.e, the one that turns clockwise will produce counterclockwise torque, which is to be balanced by the other rotor spinning counter clockwise. So the counter clockwise spinning rotor is slow) Tighten the screw that holds that rotor that is spinning more slowly. Use the screwdriver that came with the spare parts.
12/29/2013 10:25:15 PM • JCPenney... • Answered on Dec 29, 2013
0answers
Landing Gear one part of Gear broke off
Glue it back on.
12/7/2013 11:58:44 PM • JCPenney... • Answered on Dec 07, 2013
My Gyropter will not ascend? Blades run at full speed
Sounds like the battery is not charged fully. Mine did that after I pulled it out of the box. Let it charge for a while longer. Chaio!
12/7/2013 11:57:33 PM • JCPenney... • Answered on Dec 07, 2013
Brand new and right out of the box, the bottom blades do not spin at all.
The Jcpenney ones seem to have the most problem with this. Some of the gears might be out together wrong, see if Jcpenney will take it back. Chaio!
12/7/2013 11:53:20 PM • JCPenney... • Answered on Dec 07, 2013
2answers
I cHarged the helicopter and
try to play around with the trimmer.. i had the same problem but then guessed it was the trimmer and iwas right!
12/7/2013 9:00:18 PM • JCPenney... • Answered on Dec 07, 2013
3answers
The gyropter will not charge
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
12/7/2013 8:58:40 PM • JCPenney... • Answered on Dec 07, 2013
JCPenney Gyropter RC Helicopter Logo
83 questions posted
Top JCPenney Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a JCPenney Toy Expert? Answer questions, earn points and help others
View Most Popular
JCPenney Toys
  • JCPenney Toys
Most Popular Question
helicopter not turning after fell down
  • Toys
