20 Most Recent Acer PD725 Multimedia Projector Questions & Answers
Acer H7530D Projector. Hello, It does not work more than a couple of minutes. The failure log indicates System voltage = 70 or 120.
There is nothing online for that error. It sounds like your mains voltage is very low. https://www.google.com/search?q=Acer+H7530D+error+System+voltage+70+or+120 Service Manual
ACER H7530D PROJECTOR SERVICE MANUAL
ManualsLib https://www.manualslib.com > ... > H7530D Series View and Download Acer H7530D ... Page 3 H7530/H7530D Comparison List Models Parts ... Turning off (cooling completed) Error (thermal failure) Error (fan failure) ... ..
4/20/2024 6:50:35 PM • Acer Office... • Answered on Apr 20, 2024
Acer DLP projector x112. Do not turn on, fan stop, power button blinking red/blue.. please help
I had the same problem with my acer x112 , and after checking everything i found out that the problem was the Color Wheel (not necessarily being broken) , it looked new but it was the problem , hope this helps
2/13/2024 5:17:47 PM • Acer Office... • Answered on Feb 13, 2024
2answers
Acer aspire es 15 boot device missing
Great Information sharing .. I am very happy to read this article .. thanks for giving us go through info.Fantastic nice. I appreciate this post.Controle d'acces Maroc
10/5/2022 4:53:16 PM • Acer Office... • Answered on Oct 05, 2022
2answers
CANON ERROR E27
Canon MP140 Error Code injet printer reset procedure:Canon waste ink tank problem.1. Change the waste ink absorber2. Reset waste ink tank counterGo to the service menu;1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.NEXT2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.NEXT3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode. NEXT4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.NEXTEach time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.NEXTHit 4 times for waste ink counter reset.The number of the Reset button pressing LED 0 time ... Green Power off1 time ... Orange Service pattern print 2 times ... Green EEPROM print 3 times ... Orange EEPROM reset (EEPROM reset)4 times ... Green Waste ink counter reset On the end press POWER button to exit .FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
4/12/2021 12:37:51 PM • Acer Office... • Answered on Apr 12, 2021
Have problems with projector acer serie h5360 IR remote controls do not work.
HI recently repair online just few minute after your problem solve you can visit my site https://www.epsonprintersupport247.com/steps-to-fix-error-code-0x10-of-epson-printer/
5/14/2019 7:11:49 AM • Acer Office... • Answered on May 14, 2019
2answers
Acer AX1900E3502 printer iw do Iinsert disc
if this is a recent computer it might not have a cd rom drive if it is a laptop / notebook . Suggest downloading the whatever printer make and model with whatever operating system driver software. try searching {model number} {operatng system} driver download. otherwise you might be able to use a external usb cd rom drive
11/7/2018 10:23:18 AM • Acer Office... • Answered on Nov 07, 2018
My acer projector x113p shows no signal and lock symbol,how can i fix this
no PC stated connected to 113 (DLP ) projector, very nice. 5 years old , lamp life 5000hrs, min. no cable stated, VGA? DVI what>? how long is the cable 6feet (2m) or 100feet, we surely cant guess what you see there. did you test the projector any other good PC.? did you read the manual first for picking how to select inputs. did you RTM on resolution limits and set the PC to that. max on proj. is 1920 x 1200 (very good) did you buy it new or used? did it work ever, (used questions) lock (i clicked search manual and found) 1 second read PDF page 20 in your manual it tells you to push the source button, I guess you never read the manual? https://www.acer.com/ac/en/PH/content/support-product/5956?b=1
10/6/2018 12:40:30 PM • Acer Office... • Answered on Oct 06, 2018
I have been using this Acer projector but it suddenly locked. The display shows the acer logo, no signal and a lock. I can not unlock it. What must I do to unlock it. I am not using any password.
it means the projector locks on this source type and there is no such type of input signal found, so you need to try new input source type . means : if you use for example VGA, try to use other input type such DVI , HDMI
10/6/2018 7:53:49 AM • Acer Office... • Answered on Oct 06, 2018
Canon MX347 error display 5b00
CANON RESET MP347 ERROR 5BOO
8/24/2018 1:01:30 AM • Acer Office... • Answered on Aug 24, 2018
Hdmi weak signal
Turn off your screen saver. The screen saver will affect the output of the HDMI in the same way it will affect the laptop screen. Good luck. Semper Fi, Z
2/27/2018 4:12:53 PM • Acer Office... • Answered on Feb 27, 2018
Acer projector X1161p not powering up
Recommend contacting Acer directly here: https://www.acer.com/ac/en/US/content/contacts helpful-fbhtsuujths3pkuos2jmb534-5-0_2.png
2/9/2018 6:38:34 AM • Acer Office... • Answered on Feb 09, 2018
Acer PD725 Multimedia Projector Logo
5 questions posted
Top Acer Office Equipment & Supplies Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Acer Office Equipment & Supplies
Most Popular Question
connect acer projector dstv
  • Office Equipment & Supplies
