FixYa.com
Acer Mini 7765PA Multimedia Projector
All Products > Acer > Multimedia Projectors
Problems with Acer Mini 7765PA Multimedia Projector?
Search inside Acer Mini 7765PA Multimedia Projector Knowledgebase
Troubleshooting and Support
Solved Problems for Acer Mini 7765PA Multimedia Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Epson EMP-82e locked out
One of our staff turned off the projectors power. He then proceeded to input the wrong security code and the projector...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
green tint
I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing...
1 Solution
my problem is that the Image is not...
my problem is that the Image is not stable, on my projector, any suggestions?
1 Solution
CONNECT CABLE TO MY PROJECTOR
HOW DO I HOOK MY CABLE UP TO MY MITSUBISHI DLP PROJECTOR MODEL HC1500
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1100 ANSI lumens
Max Resolution (Native)1024 x 768
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Image Size (Diagonal)23.64 in. - 300 in.
Screen Distance4.59 ft. - 15.09 ft.
Lamp
Lamp TypeVIP
Standards
Analog Video FormatNTSC · PAL · SECAM
Warranty
Warranty3 Years
Dimensions
Depth9.5 in.
Height7.72 in.
Width2.4 in.
Weight5.07 lb.
Acer Contact Information
Main support number408.432.6200 1.800.733.2237
Support FAX408.922.2933
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
