FixYa.com
Acer PD525 Multimedia Projector
All Products > Acer > Multimedia Projectors
Problems with Acer PD525 Multimedia Projector?
Troubleshooting and Support
Solved Problems for Acer PD525 Multimedia Projector RSS Feed Post a New Problem
toshiba portege m600 cannot connect to...
I have never success to display my presentation if I use toshiba portege M600 and connected to projector Acer PD525. The...
1 Solution
blinking bulb light
The bulb yellow light next to the power botton is blinking. I purchased a new lamp and replaced but is still blinking, I...
2 Solutions
vt45 projector turns off without notice.
The projector turns off while in use. It doesn't really needto be "too hot". It may be in the first few...
1 Solution
Remote control for Canon LV X6 Projector
I cannot seem to get the remote control to work for the projector. I'm trying to use a PowerPoint Presentation and the...
1 Solution
user manual
hi i have this new beetel walk clip caller id cordless phone but i do not have the users manual,so i cannot load the...
1 Solution
InFoucus LP500 Projector
My InFocus LP500 projector has a pinkest image when connected to the Dell C840 laptop. I have update the display driver...
1 Solution
LCD shutting off automatically
I use a Benq LCD projector to give powerpoint presentations. Lately the projector shuts down shortly after powering up....
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Acer PD525 Multimedia Projector RSS Feed Post a New Problem
Acer PD525
The projector was workin fine, then there was a pop noise, the lamp is fine, but the unit will not power up at all, any...
Post a Solution
No Video Images
Everything works from my Fijitsu Siemens Laptop to the projector, except video. If I play a Windows Media Audio/Video...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness2600 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)1024 x 768
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)24.6 in. - 300 in.
Screen Distance3.94 ft. - 40 ft.
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Video ModesCinema
Technical Features
Operation Noise30 dB
Front Panel ControlsKeypad
Remote Control FeaturesLaser Pointer
Interfaces
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · Composite Video · Component Video
Lamp
Light Source Life2000 Hours
Other Features
Special FeaturesOn Screen Menu · Keystone Correction
Speakers Output200 W
Standards
HDTV Formats720p · 1080i
Dimensions
Depth9.33 in.
Height4.21 in.
Width10.9 in.
Weight5.4 lb.
Acer Contact Information
Main support number408.432.6200 1.800.733.2237
Support FAX408.922.2933
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
