20 Most Recent GoVideo Rave-MP ARC5.0 MP3 Player Questions & Answers
You should find your MP3 player on your PC as a Removable Disk when you connect it to USB port. sometimes it asks for a driver. If they sold you it without it, actually you don't need it. It should find the driver by itself and stat up.
If you can't see that external or removable dik, yuo got a faoulty produt or you have a bad USB port. Chech if your port is working, change it to another port, but if still nothing, your player has a failure in it's USB outlet. Take it to check for warranty
GoVideo Rave-MP... | Answered on Dec 09, 2014
This means that your unit is defective and is no longer working. The hard drive is bad.
I have bought 3 of these players. All of them worked for a while then had the eventual face/bug on the screen after turning the unit on. When the customer service number DID work, they said that the unit was defective and to return it to the store and get another.
This happened to me, like I mentioned, with 3 different units.
GoVideo Rave-MP... | Answered on Oct 01, 2009
There are 2 issues- 1 the keys are locked - unlock and turn machine off. the other option is to recharge the battery
The hard drive is probably bad. To replace it is about 60-80 dollars. Then you have to put a drive image on it. More trouble than its worth.
Hi Samusv2,
Try removing the battery completely for about 1 minute, then put it back in then try to see if doe shte same thing. Insert another comment on this post and I will respond.  Cross your fingers.
GoVideo Rave-MP... | Answered on Oct 16, 2007
Your radio is turning itself off because the power supply is failing. It has nothing to do with optical digital output.
Audio Players &... | Answered 5 hours ago
Request from the manufacturer/distributor
Audio Players &... | Answered 8 hours ago
Hi Mojalefa Koki, it is that you show in the photo a digital audio output, where you can connect a Fiber Optic cable and thus take the sound of the CD player of that device to another and be able to different actions, for example, record, amplify, as long as you get the corresponding equipment for those tasks
There, you can not connect anything that makes that equipment can be turned off, does not operate the device's function system
On the other hand, indicate brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Mojalefa Koki, eso que muestras en la foto en una salida de audio digital, donde puedes conectar un cable de Fibra ?ptica y as? llevar el sonido del reproductor de CD de ese aparato a otro y poder distintas acciones, ejemplo, grabar, amplificar, siempre y cuando tengas el equipo correspondiente para esas tareas
Ah?, no puedes conectar nada que haga que ese equipo se pueda apagar, no maneja el sistema de funciones del aparato
Por otro lado indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Audio Players &... | Answered 14 hours ago
Hi Betty, I send you the link to download the user manual of your ZS-PS50
I hope you can resolve your concern
Hola Betty, te envio el link para que descargues el manual de usuario de tu ZS-PS50
Espero que puedas resolver tu inquietud
http://www.go-gddq.com/upload/2010-03/10033015398441.pdf
https://www.appliancesonline.com.au/public/manuals/Sony-ZSPS50-Boombox-CD-Player-User-Manual.pdf
Audio Players &... | Answered Yesterday
Hola Mmdx, indique la marca, el modelo y el tipo de equipo que est? comentando para encontrar la mejor soluci?n.
Espero su respuesta.
Hola Mmdx, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Sansui QRX-7500 Manual - Four Channel Receiver - HiFi ...
www.hifiengine.com/manual_library/sansui/qrx-7500.shtml
May 21, 2014 - sansui qrx-7500 four channel receiver. Sansui QRX-7500 ... service manual English - honestsoul99. Related Catalogues. HiFi Buyers Guide.
Sansui ' Hifi Manuals Free: Service Manuals, Owners ...
Audio Players &... | Answered 2 days ago
GoVideo Rave-MP ARC5.0 MP3 Player Logo
12 questions posted
Top GoVideo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a GoVideo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • GoVideo Audio Players & Recorders
Most Popular Question
find pc
  • Audio Players & Recorders
