Hitachi CMP5000WXU 50 in. HDTV Plasma Television
Problems with Hitachi CMP5000WXU 50 in. HDTV Plasma Television?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Hitachi CMP5000WXU 50 in. HDTV Plasma...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Hitachi CMP5000WXU 50 in. HDTV Plasma Television RSS Feed
View More Results for Hitachi CMP5000WXU 50 in. HDTV Plasma Television
Questions and Unsolved Support Problems
Unsolved Problems for Hitachi CMP5000WXU 50 in. HDTV Plasma Television RSS Feed
Answer
My TV has is behaving exactly like yours, I can hear a relay click on on OFF inside the set but the... (More)
Find a Manual
Hitachi CMP5000WXU 50 in. HDTV Plasma Television Manuals & Guides
Tips & Tricks
(Post a New Tip)
Polaroid flm-373b lcd tv black screen control box no power fix
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked.... written by stiv0
Enter expert mode on LG TV
For the 44" LG DLP model RU44SZ63D...press and hold the menu button the remote control until a four digit password is requested on the screen.... written by mlapres
Tv troubles
the newer tv are just computors in disguyes.they often won't come after a power surge and have to be reset,you must unpluge from the wall and wait 10... written by bsddog87
Falt Panel Screen Cleaning
If you are trying to clean a LCD or Plasma screen, use only recommended screen cleaners. Be very careful not to rub too hard or contrast coating may... written by edcor
TV has snowy picture or displays unusable signal, no signal or no sync.
What to do if you have an all snowy picture, blue screen or the TV displays unusable signal, no signal or no sync. When using a Satellite receiver or... written by johnnydiode
how to test flyback without taking it out of the board
a) basically it has to be acted upon by a supply voltage of at least 95V to work. b) of course, assuming the horizontal deflection oscillator works,... written by palaboy
LCD Flat Screen Common Problems
Have you ever wanted to know what causes a nice LCD to give out so soon? Poor electronics components such as Capacitors. I will tell you how to spot a... written by rulds2008
To preserve the life of all your electronics
If you have a tv, vcr, dvd player, anything at all that plugs into a wall, when you turn it off with the remote control, the unit is in standby, it... written by fieldy14
WikiManual
(Post a New Chapter)
How to Mount a Plasma TV on a Wall
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's... by wikihow
How to Connect a TV to a DVD Player Without A/V Jacks
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for CMP5000WXU 50 in. HDTV Plasma Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Rate and Review the Hitachi CMP5000WXU 50 in. HDTV Plasma Television
Write a review:
Rate this product:
Would you recommend the CMP5000WXU 50 in. HDTV Plasma Television to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Hitachi CMP5000WXU 50 in. HDTV Plasma Television
Key Features
Screen Size
50 inch
Digital TV Standard
HDTV
Flat Panel Type
Plasma
Display Resolution
1280 x 768 pixels
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC · PAL · SECAM
Display Format
1080i (HDTV) · 480p (EDTV) · 720p (HDTV)
Remote Control
Remote Control
Standard
Image Quality
Contrast Ratio
900:1
Pixel Pitch
.8 mm
Brightness
340 cd/m²
Output Color
16.7 million colors
Viewing Angle
160
Audio Features
Audio Output
Variable
Audio Type
Stereo
Technical Features
Picture in Picture
With PIP
Sleep Timer
With Sleep Timer
Energy Star Compliant
Connectors
Headphone Jack
With Headphone Jack
Rear Input Connectors
1 x D-Sub (RGB PC)
Rear Output Connectors
Audio (RCA) x 1
Screen Text
Channel Labels
With Channel Labels
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 2 Watt
Dimensions
Depth
3.88 in.
Height
28.13 in.
Width
47.97 in.
Weight
85.75 lb.
Warranty
Overall Warranty
2 Years
Hitachi Contact Information
Main support number1-800-448-2244
Support FAX1-309-589-7689
Email supportsupport_usa@hitachigst.com
Describe your problem:
Top Flat Panel... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
