The TV comes on and the red light next to the power button lights up then instantly turns back off...
(More)
The TV comes on and the red light next to the power button lights up then instantly turns back off and the red light goes out. Also inside the TV when it is turned on a tiny green light comes on when the TV is turned on and there is a clicking noise 3 or 4 times then another tiny green light flickers at the same time as the clicking noise and both green lights are on at the same time for a second then both green lights go out and the TV turns off. If the TV is left unplugged for a few days and then is plugged back in it tries to come back on and turns instantly off again. Then when turned on a day later (by power button or remote) it turns on and works for about a week then has the same problem with turning itself off again when it is turned on.
the tv was on while the power was shut of by the breaker and now when i try to turn it on the red...
(More)
the tv was on while the power was shut of by the breaker and now when i try to turn it on the red light comes on just a second cant figure this out
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
