I have an Hitachi 65swx20b. My TV will work fine for a while and then the picture will dissapear....
(More)
I have an Hitachi 65swx20b. My TV will work fine for a while and then the picture will dissapear. Sound is o.k. When this happened at first I would turn the TV off and back on and it would work for awhile. Now the problem is getting worse. I have to turn the TV on and off several times before it comes back on, but it only stays on for a very short time
Pioneer SD-P6085 I am getting bowing on the top and bottom of the screen. Can it be repaired - is it...
(More)
Pioneer SD-P6085 I am getting bowing on the top and bottom of the screen. Can it be repaired - is it worth it?
My TV shuts off seconds after turning it on. I hear clicks and shuts off. Please help. Hitachi...
(More)
My TV shuts off seconds after turning it on. I hear clicks and shuts off. Please help. Hitachi 43fdx15B rear projection tv.
i have a 65swx20b hitachi crt rear projection tv when i power it up the front light goes on and the...
(More)
I HAVE A 65SWX20B HITACHI CRT REAR PROJECTION TV WHEN I POWER IT UP THE FRONT LIGHT GOES ON AND THE TV WHINES AND THEN SHUTS DOWN THIS ALL HAPPENS VERY FAST
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
