i have a hitachi 70vs810 tv when i power it up pic is all scrambled after a while it clears up .....
(More)
i have a hitachi 70vs810 tv when i power it up pic is all scrambled after a while it clears up .. happens everytime i power it up ???
My client has a Hitachi 70VS810. The input is analog RF via coax connection from the cable box to...
(More)
My client has a Hitachi 70VS810. The input is analog RF via coax connection from the cable box to the Antenna A in and the signal is clean to the TV. However, the TV has a very distorted, wavy, and green tinted image. Suggestions? Thanks!
i have the same problem with the hitachi 70vs810 re the blinking red fan light. sounds like there is...
(More)
i have the same problem with the hitachi 70vs810 re the blinking red fan light. sounds like there is a manufacturing defect with this model, i bought mine in the summer of 2005
My hitachi 70vs810 when you power on all three lights go on you can hear the fan start and then the...
(More)
My hitachi 70vs810 when you power on all three lights go on you can hear the fan start and then the T.V. powers off immedietaly before a picture is seen and the temp light stays on blinking
NOT a good time to be having a problem, FOOTBALL. It comes on but then there is a buzzing sound and...
(More)
NOT a good time to be having a problem, FOOTBALL. It comes on but then there is a buzzing sound and then turns right back off, no picture at all, I had the TV repaired exactly one year ago, light Assy, light Engine, the TV was purchased in Dec of 2004, $7000.00. I thought I would of purchased a TV that didnt need as much attention that this one has needed. I hope there is a simple non-expensive solution to my problem because I sure do enjoy watching my sports on this TV. I really do hope you can help me.
I hae a Hitachi 70VS 810 projection TV. It made a loud popping noise and shut down. Now when i try...
(More)
I hae a Hitachi 70VS 810 projection TV. It made a loud popping noise and shut down. Now when i try to power it up i believe I hear the light engine and then it stops .and pops through the speaks. Any ideas to help me fix my problem?
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D...
written by Ecollier2012
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
