I have an Hitachi 36udx10s and would like to know what type of "set-Top Box" I...
(More)
I have an Hitachi 36udx10s and would like to know what type of "set-Top Box" I need and where do I buy one in order to connect to a DirectTV HD DVR reciever for the 1080i picture. Thanks in advance for your help.
there are three solid color squares located at the top of thee screen that stay there. its also has...
(More)
there are three solid color squares located at the top of thee screen that stay there. its also has a picture, but its very fuzzy and its seems as if it needs to be fine tuned sort of speaking. what causes this?
this tv was in the garage in the winter for a week before I moved it into the house. When I plugged...
(More)
this tv was in the garage in the winter for a week before I moved it into the house. When I plugged it in it worked at first, but then I co uldn't shut it off or turn the channel, so I unplugged it and now it just has a black screen with red lines. There was a lot of condensation on the screen from the temperature change.
i have had this for a lil while and the screen started to "bow" in the center . now when i...
(More)
i have had this for a lil while and the screen started to "bow" in the center . now when i change channels the picture looks like the top is rolled over and its all staticy for a few sec. then clears up, but every now and agin it flickers a little and the top of the screen rolls down and the audio goes out. and the picture gets distorted.
I need an instruction/owners manual so I can set up my TV on my sattlelite dish. Can i download it...
(More)
I need an instruction/owners manual so I can set up my TV on my sattlelite dish. Can i download it from the net?
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear...
written by Lauren_FixYa
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method...
written by techman
Update
A number of people have commented that after changing the color wheel,
their red and blue colors are reversed. This is a different color...
written by sweet_rascal
7. Locate the color wheel cover. It?s got a small green circuit
board on top of it with a black/blue wires connected to it. Remove that
plug. Also,...
My television is model Samsung HLM4365WX and the color wheel part
number for that is BP96-00250A. This color wheel is used in many, many
Samsung...
I?ve got one of the early models of the Samsung 43′ DLP Television
sets. We?ve been through a lot together, but it?s just a...
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
