BenQ 99.JOM77.B91 Multimedia Projector
Problems with BenQ 99.JOM77.B91 Multimedia Projector?
Troubleshooting and Support
Solved Problems for BenQ 99.JOM77.B91 Multimedia Projector RSS Feed Post a New Problem
intermittent start of bulb
i was thinking this is a ballast problem. it won't hurt to take the top of the back of the tv to repair it.
1 Solution
Cannon Projector LX-V5
We are facing problem with our projector. It is all pink in colour now. kindly solve the problem as we have a...
1 Solution
Projector
Got a Saville NPX3000 projector. Powers up ok and tells me it's autosearching but won't display my computer. I got no...
1 Solution
vt45 projector turns off without notice.
The projector turns off while in use. It doesn't really needto be "too hot". It may be in the first few...
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
Remote control for Canon LV X6 Projector
I cannot seem to get the remote control to work for the projector. I'm trying to use a PowerPoint Presentation and the...
1 Solution
user manual
hi i have this new beetel walk clip caller id cordless phone but i do not have the users manual,so i cannot load the...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1600 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)800 x 600
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)22 in. - 300 in.
Screen Distance2.6 ft. - 32.8 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Horizontal20 - 88 kHz
Synchronization Range Vertical20 - 100 Hz
Video ModesStandard · Cinema · Game
Technical Features
Audio OutputSpeaker(s)
Operation Noise36 dB
Front Panel ControlsKeypad
Interfaces
InterfaceUSB
Video Input4 Pin - Mini DIN (S-Video) · 15 Pin D-Sub VGA (& component) · Composite Video
Lamp
Lamp TypeNSH
Light Source Life2000 Hours
Light Source Power200W NSH
Other Features
Special FeaturesOn Screen Menu · Keystone Correction · Picture in Picture
Speakers Output1 W
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · PAL-M · PAL-N · SECAM · NTSC 4.43 · PAL 60
HDTV Formats720p · 1080i · 480p · 576p · 480i · 576i
Warranty
Warranty3 Years, 90 Days On Lamp
Dimensions
Depth7.1 in.
Height3.4 in.
Width9.4 in.
Weight4.2 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
Loading problems.
Top Experts
Ask Me
HDTV GURU Guru
3 solutions
Ask Me
Marrie Wiz
15 solutions
Ask Me
chewy_mx Master
1 solutions
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
