FixYa.com
BenQ PB2120 Multimedia Projector
All Products > BenQ > Multimedia Projectors
Problems with BenQ PB2120 Multimedia Projector?
Search inside BenQ PB2120 Multimedia Projector Knowledgebase
Troubleshooting and Support
Solved Problems for BenQ PB2120 Multimedia Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
How do I adjust the frequency for an...
How do I adjust the frequency for an external monitor (projector)?
1 Solution
my problem is that the Image is not...
my problem is that the Image is not stable, on my projector, any suggestions?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Epson EMP-82e locked out
One of our staff turned off the projectors power. He then proceeded to input the wrong security code and the projector...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
green tint
I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for BenQ PB2120 Multimedia Projector RSS Feed Post a New Problem
shadow
hi have problem with my benq pb2120 projector it shows this shadow almost covering the hole intire frame you can still...
Post a Solution
Need Benq PB2120 Repair Person in...
I think my prisim is broken, only getting Black & White picture and it sounds like broken glass inside. Help Please...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1200 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)800 x 600
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Image Size (Diagonal)20 in. - 236.16 in.
Screen Distance2.62 ft. - 32.81 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Horizontal30 - 70 kHz
Synchronization Range Vertical50 - 100 Hz
Technical Features
Audio OutputSpeaker(s)
Operation Noise34 dB
Front Panel ControlsKeypad
Interfaces
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · Composite Video
Lamp
Lamp TypeVIP
Light Source Life2000 Hours
Light Source Power150W VIP
Other Features
Special FeaturesKeystone Correction
Speakers Output.5 W
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · SECAM · NTSC 4.43
HDTV Formats720p · 1080i · 480p
Warranty
Warranty3 Years
Dimensions
Depth6.9 in.
Height2.05 in.
Width8.67 in.
Weight3.81 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
