FixYa.com
BenQ PB6210 Multimedia Projector
All Products > BenQ > Multimedia Projectors
Problems with BenQ PB6210 Multimedia Projector?
Troubleshooting and Support
Solved Problems for BenQ PB6210 Multimedia Projector RSS Feed Post a New Problem
Viewing problem with PB6210
The power up screen with the projector, ie the BENQ logo looks fine during power up, but when I connect a PC to it the...
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
No Picture on my nec VT676 model
I use this projector as a projector for my SmartBoard and when i press the power on button, the power light goes green,...
2 Solutions
vt45 projector turns off without notice.
The projector turns off while in use. It doesn't really needto be "too hot". It may be in the first few...
1 Solution
I cannot ger the projector to project the...
I not sure how to connect the projector to a lap top. I have connected a cord from the rgb in connector to my dell...
2 Solutions
sharp digital multi media projector PG...
Screen show keeps cutting out for 5 - 20 secs although the projector is still operating and somes back on...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness2000 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)1024 x 768
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)31 in. - 300 in.
Screen Distance4.5 ft. - 32 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Horizontal20 - 88 kHz
Synchronization Range Vertical20 - 100 Hz
Technical Features
Audio OutputSpeaker(s)
Operation Noise30 dB
Interfaces
Video Input4 Pin - Mini DIN (S-Video) · 15 Pin D-Sub VGA (& component) · Composite Video
Lamp
Lamp TypeNSH
Light Source Life2000 Hours
Light Source Power200W NSH
Other Features
Special FeaturesOn Screen Menu · Keystone Correction
Speakers Output1 W
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · SECAM
HDTV Formats720p · 1080i · 576p
Dimensions
Depth8.5 in.
Height3.9 in.
Width10.3 in.
Weight6 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
