FixYa.com
BenQ PE8700 Multimedia Projector
All Products > BenQ > Multimedia Projectors
Problems with BenQ PE8700 Multimedia Projector?
Troubleshooting and Support
Solved Problems for BenQ PE8700 Multimedia Projector RSS Feed Post a New Problem
Benq PE8700 - Won't Power Up
The projector was working one day & then it wouldn't. I always had the unit left in stand-by mode. Went to turn it...
1 Solution
BenQ PE8700
Did you make any progress on the problem I'm having. Thanks
1 Solution
dvi input problems
not picking up dvi signal from sat reciever  .  worked for two years , havnt changed anything......
1 Solution
PE8700+
Hello! I have a Pe8700+ with just over 1000 hours on the bulb. In start up the power goes on and the unit tries to start...
1 Solution
lamp replacement
The projector lamp went out so a new bulb was bought. after following the instructions for replacing the bulb there is...
1 Solution
ringing sound with fan?
Most of the time when the fan is running I get a high pitched ringing sound that is very annoying. I already have...
1 Solution
BenQ PE8700
I'm getting no where with this here in the US with BenQ's customer support. I don't know if you could help but but this...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for BenQ PE8700 Multimedia Projector RSS Feed Post a New Problem
benq pe 8700 problem
Haven't heard from you in a while. Any progress on my benq pe8700 problem?
Post a Solution
update BenQ PE8700
Hope this is not getting too old for you? I appreciate your help! Spoke with BenQ again, still not helpful. They insist...
Post a Solution
mainboard replacement
do you know what specifically is the problem with the mainboard in this scenario?
Post a Solution
Screen lock up and B&W shred screen
HI I have a PE 8700 which has been giving me trouble for quite a while. It typically works for a couple hours then the...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
TypeDLP Projector
Form FactorDesktop
Display TechnologyDLP
Image Brightness1000 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)1280 x 1024
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Image Size (Diagonal)31.5 in. - 252 in.
Screen Distance3.28 ft. - 32.81 ft.
Color Support24-bit (16.7M colors)
Synchronization Range Horizontal15 - 80 kHz
Synchronization Range Vertical50 - 100 Hz
Technical Features
Audio OutputSpeaker(s)
Operation Noise30 dB
Interfaces
Video Input4 Pin - Mini DIN (S-Video) · 5-Wire (BNC) · DVI-I · Composite Video · Component Video
Lamp
Lamp TypeVIP
Light Source Life2000 Hours
Light Source Power210W VIP
Other Features
Special FeaturesOn Screen Menu · Keystone Correction · Picture in Picture
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · SECAM · NTSC 4.43
HDTV Formats720p · 1080i · 480p · 480i
Warranty
Warranty3 Years
Dimensions
Depth15.05 in.
Height5.12 in.
Width15.76 in.
Weight14.77 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
