FixYa.com
BenQ PB6200 Multimedia Projector
All Products > BenQ > Multimedia Projectors
Problems with BenQ PB6200 Multimedia Projector?
Troubleshooting and Support
Solved Problems for BenQ PB6200 Multimedia Projector RSS Feed Post a New Problem
How do I adjust the frequency for an...
How do I adjust the frequency for an external monitor (projector)?
1 Solution
optoma projector
We are having problems with our projector. The screen (or light bulb) flickers. We have had it just a little over a year...
1 Solution
CONNECT CABLE TO MY PROJECTOR
HOW DO I HOOK MY CABLE UP TO MY MITSUBISHI DLP PROJECTOR MODEL HC1500
1 Solution
LCD shutting off automatically
I use a Benq LCD projector to give powerpoint presentations. Lately the projector shuts down shortly after powering up....
1 Solution
paint your website area by giving...
how can you paint your website area by giving coordinates ?
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
White vertical line in the center of...
We have had our X2 for about 3.5 years and not changed the bulb out. Within the last two weeks, a vwrtical white line,...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for BenQ PB6200 Multimedia Projector RSS Feed Post a New Problem
stuck in blank mode
Our Benq PB6200 appears to be stuck in blank mode. Projector appears to be turning on normally but, we never see the...
Post a Solution
screen
The right side of the picture is dim and the left side is fine. Already looked at the bulb and the set up. What can it...
Post a Solution
Vertical white lines and color is way off...
Whenever I turn on the projector, a series of Vertical White lines cover the screen. Also the color is way off on the...
Post a Solution
cant see dark images
My problem with my Benq 6200 is that I have lost contrast, Any dark(black)image shows up as a spotty white/grey...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1700 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)1280 x 1024
Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen)
Image Size (Diagonal)40 in. - 300 in.
Screen Distance2.6 ft. - 32.8 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Horizontal20 - 88 kHz
Synchronization Range Vertical20 - 100 Hz
Technical Features
Operation Noise34 dB
Interfaces
InterfaceWired Remote Control (3.5 mm Mini Jack)
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · Composite Video
Lamp
Lamp TypeNSH
Light Source Life2000 Hours
Light Source Power200W NSH
Other Features
Special FeaturesOn Screen Menu · Keystone Correction · Picture in Picture
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · SECAM · NTSC 4.43
HDTV Formats720p · 1080i · 480p
Warranty
Warranty3 Years
Dimensions
Depth8.48 in.
Height3.85 in.
Width10.31 in.
Weight5.9 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
