FixYa.com
BenQ PB6110 Multimedia Projector
All Products > BenQ > Multimedia Projectors
Problems with BenQ PB6110 Multimedia Projector?
Troubleshooting and Support
Solved Problems for BenQ PB6110 Multimedia Projector RSS Feed Post a New Problem
Not working on my laptop
hi, here's my problem... My projector is working on boot-up but when it came to the windows it is not... I'm wondering...
1 Solution
BenQ PB6100
Why Isnt It Working In Colour?
2 Solutions
Benq 6110 - mounting projector onto...
Help required to get the image flipped correctly when trying to mount the projector onto the ceiling
1 Solution
Lamp goes out
Lamp goes out after about 20 minutes of operation, does come back on after pressing the power button again, but not for...
2 Solutions
BenQ 6110
Did you fix the fuzziness problem on s-video for the BenQ 6110?
1 Solution
unclear, fuzzy image
When I use the monitor cable, the image is fine. When I use the s-video cable, the image is very unclear.
1 Solution
Projector
when I hook up to the laptop I don't get a picture ???? Do I have to do something on the computer to make it work ????
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for BenQ PB6110 Multimedia Projector RSS Feed Post a New Problem
Can I reset the counter without changing...
Hi gang, My lamp is almost 2900 hours old, but still running very well. I've read that at 2900 hours I will have to...
Post a Solution
colour wheel
Hi I have a benQ PB6210 with that same issue ,how did you go fixing it and how expensive was the part. Cheers Russell...
Post a Solution
projector vibes
G'day there, I am hoping that someone out there may have a trashed Benq PB6110 as mine has a chipped colour wheel. iIt...
Post a Solution
BenQ 8700
I have contacted BenQ about this problem and they insist that there is no firmware upgrade for this product or anything...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1500 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)800 x 600
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)40 in. - 300 in.
Screen Distance2.6 ft. - 32.8 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Horizontal20 - 88 kHz
Synchronization Range Vertical20 - 100 Hz
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack
Operation Noise31 dB
Interfaces
InterfaceUSB
Video Input4 Pin - Mini DIN (S-Video) · 15 pin D-Sub VGA x 2 · Composite Video
Lamp
Lamp TypeNSH
Light Source Life2000 Hours
Light Source Power200W NSH
Other Features
Special FeaturesOn Screen Menu · Keystone Correction
Speakers Output1 W
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · SECAM · NTSC 4.43
HDTV Formats720p · 1080i · 480p · 576p
Dimensions
Depth8.5 in.
Height3.9 in.
Width10.3 in.
Weight6 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
