FixYa.com
BenQ PB6100 Multimedia Projector
All Products > BenQ > Multimedia Projectors
Problems with BenQ PB6100 Multimedia Projector?
Troubleshooting and Support
Solved Problems for BenQ PB6100 Multimedia Projector RSS Feed Post a New Problem
blue screen
When I turn on the projector, it comes up with the BenQ logo. After that there is just a blue screen. It usually has...
1 Solution
Projector shuts down after only a few...
After somewhere between 10-30 mins of operation, the projector seems to turn itself off. The projector will blank out...
3 Solutions
It just shows a blank white screen when I...
It just projects a blank white screen when switched on, and also it becomes unresponsive to the buttons. It doesn't show...
1 Solution
cleanin problem
how do I cleang filter
1 Solution
BENQ PB2140 PROJECTOR - RESET LAMP AFTER...
I am on Norfolk Island (South Pacific) and very isolated in terms of assistance. I have replaced the lamp. The old lamp...
1 Solution
RAGO
HELLO FROM MEXICO CITY MY QUESTION IS, HOW CAN I CHANGE THE FIRST SCREEN. I WANT TO MY NAME IN MY BENQ PB6100? I NEED TO...
1 Solution
How to Use remote to forward slides of PP...
I need this info ASAP for a work project. I can easily forward the slides if I press enter on my laptop but this limits...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for BenQ PB6100 Multimedia Projector RSS Feed Post a New Problem
BENQ PB 6100 ( WON'T START DEVICE)
HI, I HAVE THAT BRAND AND FOR SOME REASON THE EQUIPMENT CAN'T STARTED. I WAS IN DOMINICAN REPUBLIC USING THAT AND I ...
Post a Solution
BENEQ Projectors
The icons displayed on the monitor do not show on the screen
Post a Solution
Problem With Benq PB6100 the Red Lamp...
About 8 Out of 10 times when I turned on my PB6100 Projector the Fan started to run in a very high speed for a few...
Post a Solution
light
light hours getting close to 3000, but picture still looks good,will resetting lamp hour hurt and keep using same lamp...
Post a Solution
dust in the lens mechanism
i have problem with dust in lens mechanism.It is very apparent in dark scenes, when u see big blobs.I wonder what is the...
Post a Solution
BenQ PB6100
Mi proyector no tiene reconoce se?al en la entrada video. Cuando lo conecto en super video la se?al sale en blanco y...
Post a Solution
Cleaning dust and dirt from the lens...
How do you safely clean the optics of a 6100. I can see dust particles on the inside of the lens (looking through the...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness1500 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)800 x 600
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)31 in. - 250 in.
Screen Distance2.6 ft. - 32.8 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1280 x 1024 (SXGA)
Synchronization Range Horizontal20 - 88 kHz
Synchronization Range Vertical20 - 100 Hz
Technical Features
Operation Noise34 dB
Front Panel ControlsKeypad
Interfaces
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · Composite Video
Lamp
Lamp TypeUHP
Light Source Life2000 Hours
Light Source Power200W UHP
Other Features
Special FeaturesOn Screen Menu · Keystone Correction · Picture in Picture
Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · SECAM · NTSC 4.43
HDTV Formats720p · 1080i · 480p
Warranty
Warranty3 Years
Dimensions
Depth3.15 in.
Height8.31 in.
Width10.16 in.
Weight5.6 lb.
BenQ Contact Information
Main support number(866) 600-2367
Support FAX(949) 255-9500
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
