20 Most Recent Karbonn Cell Ranger STIX 12V Cell Phone Booster Questions & Answers
Hello Jeff, I was looking for the user manual of your CB Radio Hatadi, to know what fuse it takes and there is no information
I would try the 5 Amp, I would place it and it would work for a long time to the BC Radio, checking that the fuse resists the transmission work
If it does not resist, I would put the 10 Amp and would do the same test
If it does not resist either, then you already have problems with the equipment
If so, look for a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Jeff, estuve buscando el manual de usuario de tu CB Radio Hatadi, para saber que fusible lleva y no hay informacion
Yo probar?a con el de 5 Amp, lo colocar?a y har?a funcionar por un rato largo al BC Radio, comprobando que el fusible resista el trabajo de trasmisi?n
Si no resiste, pondr?a el de 10 Amp y har?a la misma prueba
Si tampoco resiste, entonces ya tienes problemas en el equipo
Si es as? busca un servicio t?cnico especializado
Espero Puedas resolver el problema
Saludos Franco Dosil
Radio... | Answered 12 hours ago
https://www.cardosystems.com/support/g9x get help from above link, it is user guide and some problem and their solutions.
Radio... | Answered 2 days ago
https://www.test-guide.com/free-gre-practice-tests.html
See this site, and if you want to appear you can do practice for examination.
Its better you change the speaker if you need more audio otherwise its ok, at least your hearing the sound.
Raymarine Ray55 Manuals Down Load user manual and reset MMSI according instructions.
Radio... | Answered 3 days ago
You have the modulation problem. If you have hand free you connect it and try to send message, if other unit hear you then it mean your microphone has faulty and replace the microphone, the fault is in mic or other circuit from mic input to modulation device which may be any transistor , capacitor or any resistance faulty. Consult with any Radio Service Shop.
You check your radio with other radio very near. If radio is hearing your transmission then it mean that your Radio Power Module not working if very near radio not listening you then your preamplifier and Power amplifier is not working, it mean your Radio Transmitter faulty, only Receiver is working, you consult with any Radio Service shop. One other thing if you have software also check Tx/Rx frequency it must be same for simplex operation.
https://www.gme.net.au/media/2444484/tx3350_im_web.pdf
Download user manual from above link and read page 12 for scanning.
heck out this site it has the alignmet procidure to set the squeltch and RF power output , Also a great easy mod for 400 yes 400 channels , enjoy http://radioaficion.com/cms/president-lincoln-ii-mod-400-channels
Radio... | Answered on May 19, 2019
search for instruction manual
Radio... | Answered on May 18, 2019
Karbonn Cell Ranger STIX 12V Cell Phone Booster Logo
0 questions posted
Top Karbonn Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Karbonn Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Karbonn Radio Communications
Most Popular Question
set up tx3350 cb radio monitor 2 x
  • Radio Communications
