I call the fax machine from a normal landline phone and the fax machine picks up the call after 2...
(More)
I call the fax machine from a normal landline phone and the fax machine picks up the call after 2 rings - this is good (you can hear the fax machine noises in the hand set). I send a fax to the machine from a remote/outside fax machine, the remote dials and then I hear a message stating that the number dialed is not connected. Why? I dial the same number in both cases. How to fix?
I have reinstalled the OS and tried a USB as well as a parallel connection with no success. The...
(More)
I have reinstalled the OS and tried a USB as well as a parallel connection with no success. The following is the message I'm getting: "MultiPASS Unable to communicate with the device. Please start "MPService" from the Services applet in the Control Panel. Then please right-click on the Status Monitor to Reconnect and try again." I have followed the recommended fix with limited success. However there has not been a permanent solution.
Remove and discard the drum cover on the bottom of the cartridge, they come unhooked and cause jamming. It's only there for shipping.
written by leroyal
Internet fax services are a great way to save time and money on fax communications. Your company can save hundreds or thousands of dollars with an...
by wikihow
Full service mobile shredder repair service to inc... Read More
Full service mobile shredder repair service to include mobile shredder and collection trucks as well as stationary shredders 5-200hp.
Call 877-4FIXSHRED
Authorized Service Center or Allegheny, Ame... Read More
Authorized Service Center or Allegheny, Amerishred, Shred-Tech, Weima, Balemaster, Maren,all makes of mobile and staionary shredders, balers, equipment repaired. Hard to find parts machined, Mobile Service 5 state area.
PRINTER SERVICE USA provides factory-authorized ser... Read More
PRINTER SERVICE USA provides factory-authorized service providers for all types of office equipment and trouble shoot and repair faster and more economically than anyone else in the industry. Your equipment will be repaired to 100% specifications.
So many choices, so little time?
PC REPAIR can hel... Read More
PC REPAIR can help you determine the best type of PC to fit your needs and budget, and provide the best sources for acquiring it. PC REPAIR can even procure or build the system for you if appropriate (as in the case of Custom/High-performance PCs).
Our commitment to client satisfaction extends acr... Read More
Our commitment to client satisfaction extends across the nation! Regardless of your location, a technician is available through our network of authorized dealers/repair centers to handle your technical needs. You can reach our PL/HQ at 212-633-6807 and our staff will dispatch a service technician.
