20 Most Recent
CircuPool Salt Water Pool System Questions & Answers
Kinetico Quad 50 troubleshoot or replace?
it's not a car or truck so moved you to water filters
call 3 plumbers, get 3 quotes. as grand dad said and is 100 % right.
learn to do your own shopping, and quotes./
nobody here can inspect any thing like that deeps inside,
nobody. ( no bore cam photo's x 25 presented)
ask only the living, hands on plumbing techs.
some do if for free even, (diagnosis or small charge)
ask the living not the blind.
what does BETTER mean, ask 10 persons get 10 answers to that
I'd by pass it and and send it to the dumps,. if was here.
our water is clean here, USA> (no lead pipe here)
the water tests here pass all tests. by wide margins !!! 100% safe.
to be frank, I do not trust things like that in my home. as it can be nasty inside ,and be unseen by me. ( noodle that?)
even if you go on long vacations it can get nasty inside.
yes it is too old
or get more quotes.
or bypass it,
or upgrade it
or go ROS, reverse osmosis.sys..
ROS wastes lots of water, maybe banned in CALIF. IDK
Ceramic water dispenser overflows
Contact the maker of this mystery water bottle dispenser. It sounds like it needs replacing under warranty. However.....
SOLUTION by OP: there was a hairline crack that did not show up until the plastic water bottle was inverted & the pressure /exchange between both bottle & crock caused enough "pull" to cause spillover the top of the crock. I have a secondary polycarb bottle (3gal) which is working perfectly. Simple physics, once again..
My waterwise distiller 3200 light turns on flashes then turns off
Hi Frances,
hope you are well and safe, Please have a look at the given solution.
To turn Distiller on or off, press the "Start/Stop" button. When turning Distiller on, "On" appears in the display window and the "On" (red) light illuminates (fig. B). After turning Distiller off, the "On" light turns off.
What is a water distiller?
A water distiller is a device that removes most impurities from water, through distillation. Distillation means boiling the water and then collecting the condensed steam into a clean container.
